[Geomoose-users] Adding every layer from an ArcGIS WMS Server?
Jim Klassen klassen.js at gmail.com
Mon May 18 08:48:28 PDT 2015
I am not sure about how ArcGIS does things, but with MapServer the
layers are in a hierarchy and if you turn activate the parent, all the
child layers get activated as well. However, this means that GeoMoose is
only working with the parent layer so it wouldn't be possible to
activate the child layers individually.
It looks like (from GetCapabilities) that either "AirPhotos1938" or
"Layers" might work as a top level layer name for your service.
On 05/15/2015 03:59 PM, Eli Adam wrote:
> Hi Mark and Bob,
> Surprising that ArcGIS doesn't also offered it as a single composite
> layer.  It might be worth digging through the documentation for that.
> You could also easily directly access a bunch of rasters with
> MapServer, http://gdal.org/gdaltindex.html.
> Best regards, Eli
> On Fri, May 15, 2015 at 11:15 AM, Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us> wrote:
>> Hi Mark,
>> You would probably not be able to get away from needing to define  all the
>> layers you want, but having said that, you should be able to pass the many
>> layered WMS through Mapserver (as a client) and then pass off a new
>> composite layer with Mapserver (as a service).
>> there might be an option available using a REGEX inside a SLD request.
>> bobb
>> On May 15, 2015, at 11:49 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Hello,
>> I created a WMS server using ArcGIS.  The map that I published includes 201
>> historic images of our county.  By default ArcGIS lists each image
>> separately such as layer 1, layer 2, layer 3 etc.  I would like to add the
>> WMS service to GeoMOOSE but I want to avoid listing each layer separately.
>> Is there a way to pull in all the layers from a WMS source so I don’t have
>> to list off 201 layers?
>>                 <map-source name="AirPhotos1938" type="wms"
>> reference="false" projection='EPSG:103749' tiled="true" width='256'
>> height='256' transition_Effect="resize">
>> <url>http://gis.lyonco.org/arcgis/services/LyonBasemaps/1938AirPhotos/MapServer/WMSServer?</url>
>>                                                 <layer name="1"/>
>>                                                 <layer name="2"/>
>>                                                 <layer name="3"/>
>>>>                                                 <layer name="201"/>
>>                                                 <param name="STYLES"
>> value=""/>
>>                 </map-source>
>> Thank You!
>> Mark Volz
>> Lyon County GIS
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
