[Geomoose-users] Adding every layer from an ArcGIS WMS Server?
Mark Volz MarkVolz at co.lyon.mn.us
Mon May 18 10:27:50 PDT 2015
Hello,
Thank you everyone for your help
Through a process I eventually went back to MapServer and Tile Indexes that proved to be a much better solution.   See http://www.mapserver.org/optimization/tileindex.html for an example
If anyone cares to use ArcGIS I would recommend creating a layer group.  I chose not to use ArcGIS because if was getting a blank image when I used source=wms, and pink tiles with source=ags.  I am curious as to why the ArcGIS service was slow on this application.
Sincerely,
Mark Volz, GISP
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-
> bounces at lists.osgeo.org] On Behalf Of Jim Klassen
> Sent: Monday, May 18, 2015 10:48 AM
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Adding every layer from an ArcGIS WMS Server?
> I am not sure about how ArcGIS does things, but with MapServer the layers are
> in a hierarchy and if you turn activate the parent, all the child layers get
> activated as well. However, this means that GeoMoose is only working with the
> parent layer so it wouldn't be possible to activate the child layers individually.
> It looks like (from GetCapabilities) that either "AirPhotos1938" or "Layers"
> might work as a top level layer name for your service.
> On 05/15/2015 03:59 PM, Eli Adam wrote:
> > Hi Mark and Bob,
> > Surprising that ArcGIS doesn't also offered it as a single composite
> > layer.  It might be worth digging through the documentation for that.
> > You could also easily directly access a bunch of rasters with
> > MapServer, http://gdal.org/gdaltindex.html.
> > Best regards, Eli
> > On Fri, May 15, 2015 at 11:15 AM, Basques, Bob (CI-StPaul)
> > <bob.basques at ci.stpaul.mn.us> wrote:
> >> Hi Mark,
> >> You would probably not be able to get away from needing to define
> >> all the layers you want, but having said that, you should be able to
> >> pass the many layered WMS through Mapserver (as a client) and then
> >> pass off a new composite layer with Mapserver (as a service).
> >> there might be an option available using a REGEX inside a SLD request.
> >> bobb
> >> On May 15, 2015, at 11:49 AM, Mark Volz <MarkVolz at co.lyon.mn.us>
> wrote:
> >> Hello,
> >> I created a WMS server using ArcGIS.  The map that I published
> >> includes 201 historic images of our county.  By default ArcGIS lists
> >> each image separately such as layer 1, layer 2, layer 3 etc.  I would
> >> like to add the WMS service to GeoMOOSE but I want to avoid listing each
> layer separately.
> >> Is there a way to pull in all the layers from a WMS source so I don’t
> >> have to list off 201 layers?
> >>                 <map-source name="AirPhotos1938" type="wms"
> >> reference="false" projection='EPSG:103749' tiled="true" width='256'
> >> height='256' transition_Effect="resize">
> <url>http://gis.lyonco.org/arcgis/services/LyonBasemaps/1938AirPhotos/MapS
> erver/WMSServer?</url>
> >>                                                 <layer name="1"/>
> >>                                                 <layer name="2"/>
> >>                                                 <layer name="3"/>
> >>                                                 <layer name="201"/>
> >>                                                 <param name="STYLES"
> >> value=""/>
> >>                 </map-source>
> >> Thank You!
> >> Mark Volz
> >> Lyon County GIS
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
