[Geomoose-users] Feature Report error with Identify Tool
Fernando nando_gcia at hotmail.com
Wed May 27 02:44:04 PDT 2015
Hello again, after making the "Identify" tool to work properly, I added the option "feature_report" but fails.
My identify.html file is:
<! - MapServer Template ->
<Tr bgcolor = "# DEE5EB"> <td colspan = "2"> <b> <u> SPACE </ u> </ b> </ tr>
<Tr>
<Td align = "right"> <b> IDENTIFIER: </ b> </ td>
<Td>
 [dxf_text] <a
href="javascript:GeoMOOSE.startService('feature_report',
{'dxf_text':'[dxf_text]','src':'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">
 Report </ a> </ td>
</ Tr>
<Tr>
<Td align = "right"> <b> Content: </ b> </ td>
<Td> [content] </ td>
</ Tr>
My map file is:
MAP
    NAME EDIFICIO_C2_MAP
    STATUS ON
    SIZE 800 800
    EXTENT -136 -1 227 362
    UNITS METERS
    INCLUDE "./geomoose_globals.map"
    IMAGECOLOR 255 255 255
    IMAGETYPE PNG
    SYMBOLSET "./symbols/symbol.sym"
    FONTSET "./fonts/fontset.list"
    TRANSPARENT FALSE
    RESOLUTION 100
    DEFRESOLUTION 100
    CONFIG "MS_ERRORFILE" "/ms4w/ms_error_c2.txt"
    DEBUG 5
  OUTPUTFORMAT
  NAME png
  DRIVER "AGG/PNG"
  MIMETYPE "image/png"
  IMAGEMODE PC256
  EXTENSION "png"
  FORMATOPTION "GAMMA=0.75"
END
My parcel.xml file is:
<feature-report>
    <!-- query informtion -->
    <query item="dxf_text" string="%qstring%"/>
    <!-- This is the template -->
    <template>parcel_template.pdf</template>
    <!-- this is the location of the map in the template -->
    <map x="0.92" y="2.18" w="6.69" h="3.68"/>
    <!-- This is a list of where the fields are to be printed on the template -->
    <fields>
        <field x=".5" y="7.25" src="%dxf_text%" title="IDENTIFICADOR:"/>
        <field x=".5" y="7.45" src="%contenido%" title="CONTENIDO:"/>
        <field x=".5" y="8.25" src="%area%" title="AREA:" format='%0.2f'/>
        <field x=".5" y="8.45" src="%perimeter%" title="PERIMETRO:"/>
    </fields>
</feature-report>
Test search results:
Detailed information for the area you clicked on the map ...
Ground Coordinates
X: 116.27685546875
Y: 299.78662109375
SPACES
IDENTIFIER: 16C2BN001   Report
CONTENTS: DEPARTMENT HALL. PHYSICAL
LOCATION TYPE: HALL
USE TYPE: COMMON AREA
Error when I click on the hyperlink "Report":
Warning: layerObj :: queryByRect (): [MapServer Error]:
msPostGISLayerWhichShapes (): Error executing query: ERROR: syntax error
 at or near "C2BN001"
LINE 1: ... -1 362.227 362.227 -136 -1 -136 -1)) ', 3857) and (16C2BN001)
  in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php on line 72
Warning: MapObj :: SetExtent (): [MapServer Error]: SetExtent (): Given extent map is invalid. Check That it is in the form: minx, miny, maxx, maxy
 in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php on line 100
Fatal error: Uncaught exception 'MapScriptException' in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php: 100
Stack trace:
# 0 C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php (100) mapObj-> SetExtent (0, 0, 0, 0)
# 1 {main}
  thrown in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php on line 100
Can anyone help me fix the error?
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150527/d91e421c/attachment.html>
More information about the Geomoose-users mailing list
