[Geomoose-users] PHP/MAPSCRIPT IN UNIX
Dan Little theduckylittle at gmail.com
Wed Dec 7 07:31:32 PST 2016
As I mentioned before, please "Reply All" to the mailing list.
That does not install PHP Mapscript.  You haven't answered the questions
that have been asked.  Please refer to the link I gave you which includes
PHP MapScript install instructions.
On Wed, Dec 7, 2016 at 9:29 AM, Janet Maina <madamjanet92 at gmail.com> wrote:
> Thanks for your explanation. In my mapserver I can see mapscript already
> installed as shown by a screenshot from firezilla.
> [image: Inline image 1]
> On Wed, Dec 7, 2016 at 3:56 PM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> Let me try to explain then:
>> 1. PHP/MapScript is a library MapServer publishes to allow the PHP
>> programming language to work with the MapServer API.  More info is
>> here: http://mapserver.org/mapscript/php/php_intro.html
>> 2. GeoMoose 2.X series requires PHP mapscript for any of the 'buttons'
>> like Print and Identify to work.  Our scripts are dependent on it.
>> GeoMoose 3.X will be different but that's not going to be mature
>> enough for a little while for me to recommend it.
>> 3. MS4W, presumably the package you used on windows, comes with
>> MapServer and PHP Mapscript.  That is why it "just worked."
>> So all of the install instructions you've posted are insufficient for
>> making the install work.
>> For ettiquette reasons please be advised of the following:
>> 1. It is easier to follow your progress and problems if you keep your
>> messages as "replies" to the same "thread" you've already started.
>> 2. It will be easier for us to help you if you answer questions we've
>> asked you already, including:
>>  - What Linux distribution are you running?
>>   Answering questions that experienced users *and the primary
>> developer of GeoMoose* have asked you can aid them in making your
>> experience a successful one.
>> On Wed, Dec 7, 2016 at 12:40 AM, Janet Maina <madamjanet92 at gmail.com>
>> wrote:
>> > I tried to follow the
>> > documentation''http://docs.geomoose.org/master/docs/install_unix.html"
>> and
>> > adjusted my code but am unable to install
>> > php/mapscript
>> > mapserver runs well but i don't understand the concept of mapscript and
>> no
>> > clear explanation in mapserver documentation
>> > ===============my code===========
>> > mkdir buid
>> > cd build
>> > wget http://download.osgeo.org/mapserver/mapserver-7.0.3.tar.gz
>> > tar -xf mapserver-7.0.3.tar.gz
>> > cd mapserver-7.0.3
>> > ./configure --prefix=$HOME --with-gif=no --with-fastcgi=no --with-proj
>> > --with-gdal --with-ogr --with-postgis=/usr/bin/pg_config
>> > --with-wfs--with-wmsclient--with-wfsclient
>> > make
>> > make install
>> > my site "http://www.waterresources.co.ke/data/htdocs/geomoose.html"
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161207/7cfce010/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161207/7cfce010/attachment-0001.png>
More information about the Geomoose-users mailing list
