[Geomoose-users] mapscript installation in Centos Os
James Klassen klassen.js at gmail.com
Thu Dec 8 10:57:34 PST 2016
What version of CentOS?
One thing you need to watch out for in RHEL/CentOS is SELinux is usually
enabled and limits what is allowed to run, especially if you don't install
from packages. I haven't used CentOS in awhile so I don't know offhand what
might need to be changed.
Why aren't you using prebuilt packages for MapServer and MapScript?  I am
pretty sure MapServer is available in EPEL [1].
[1] https://fedoraproject.org/wiki/EPEL
On Dec 8, 2016 11:51, "Janet Maina" <madamjanet92 at gmail.com> wrote:
> I have tried all my best to make identify and print button work but no
> success.
> I think there is a simpler solution for doing this.
> These are my configjure codes
>  mapserver-6.2.2]$ ./configure --prefix=$HOME --with-gif=no
> --with-fastcgi=no --with-proj --with-gdal --with-ogr
> --with-postgis=/usr/bin/pg_config --with-wfs--with-wmsclient--with-wfsclient
> --with-php=/usr/local/bin/php70-config
> configure: WARNING: unrecognized options: --with-wfs--with-wmsclient--
> with-wfsclient
> MapServer is now configured for x86_64-unknown-linux-gnu
> -------------- Compiler Info -------------
>   C compiler:                gcc -O2  -Wall -Wdeclaration-after-statement
> -DNDEBUG
>   C++ compiler:              g++ -O2  -Wall -DNDEBUG
>   Debug:
>   Generic NINT:
> -------------- Renderer Settings ---------
>   OpenGL support:
>   zlib support:
>   png support:              -DUSE_PNG
>   gif support:
>   jpeg support:              -DUSE_JPEG
>   freetype support:          -DUSE_FREETYPE
>   iconv support:            -DUSE_ICONV
>   AGG support:              internal
>   GD support:
>   Cairo (SVG,PDF) support:
>   Cairo SVG symbol support:
>   KML support:
> -------------- Support Libraries ---------
>   Proj.4 support:            -DUSE_PROJ
>   Proj Fastpaths:
>   Libxml2 support:
>   FriBidi support:
>   Curl support:
>   FastCGI support:
>   Exempi support:
>   Threading support:
>   GEOS support:
>   XML Mapfile support:
>   XSLT support:
>   EXSLT support:
> -------------- Data Format Drivers -------
>   PostGIS support:          -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
>   ArcSDE support:
>   OGR support:              -DUSE_OGR
>   GDAL support:              -DUSE_GDAL
>   Oracle Spatial support:
> -------------- OGC Services --------------
>   WMS Server:                -DUSE_WMS_SVR
>   WMS Client:
>   WFS Server:
>   WFS Client:
>   WCS Server:
>   SOS Server:
> -------------- MapScript -----------------
>   PHP MapScript:            yes
>   Python MapScript:          no
> However running make shows this,
> lib -I/usr/local/include/php56/ext/ereg/ -c error.c  -fPIC -DPIC -o
> .libs/error.o
> In file included from /usr/local/include/php56/main/php.h:39:0,
>                 from php_mapscript.h:35,
>                 from error.c:32:
> error.c: In function 'zim_errorObj___get':
> /usr/local/include/php56/Zend/zend_API.h:583:14: error: called object
> 'zend_error' is not a function or function pointer
>     zend_error(E_ERROR, "String size overflow"); \
> Kindly give me the link to Geomoose 3.x series too
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161208/cc2be52b/attachment.html>
More information about the Geomoose-users mailing list
