[Geomoose-users] startup service
Brent Fraser bfraser at geoanalytic.com
Tue Mar 22 13:49:51 PDT 2016
Hi devs,
   In my task to upgrade my digitizing app, I see a couple of things:
1.  That specifying a startup service in the URL  disables the tools in
the toolbar
2.  Specifying a startup service in the mapbook or in config.js doesn't
seem to work.  And I can't find any place in the code where
startup_service is referenced.
So I added a few lines to main.js (at line 73):
         var params = GeoMOOSE.getUrlParameters();
         if(GeoMOOSE.isDefined(params.call)) {
             var service_name = params.call;
             delete params.call;
             GeoMOOSE.startService(service_name, params, true);
*        /*  --- new: --- */**
**if(GeoMOOSE.isDefined(CONFIGURATION['startup_service'])) { **
**            var service_name = CONFIGURATION['startup_service'];**
**            GeoMOOSE.startService(service_name, params, true);**
while it does start the service in the config.js, but it has the same
effect on the toolbar as specifying "?call=myservice" in the URL (it is
disabled).
   Is there something special I need to set to enable the toolbar after
a startup service?
Best Regards,
Brent Fraser
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160322/2136d71a/attachment.html>
More information about the Geomoose-users mailing list
