[Geomoose-users] startup service
Dan Little theduckylittle at gmail.com
Tue Mar 29 13:10:20 PDT 2016
The disabling of the toolbar is actually a new usability 'feature.'  One of
the big struggles that both Jim and Eli found in the UI was the order of
operations when multiple services were starting at the same time due to the
'open' nature of the toolbar operation.  You can see this in operation in
the current demo when you click the "Search Parcels" tab.  The only way to
get the toolbar back is to click "cancel" which allows the service to clean
itself up properly.
If you've got a specific tab that you want displayed all the time it may be
necessary to write it as a custom-tab extension.  Which in 2.9 is going to
get a bit easier.
On Tue, Mar 22, 2016 at 3:49 PM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Hi devs,
>   In my task to upgrade my digitizing app, I see a couple of things:
> 1.  That specifying a startup service in the URL  disables the tools in
> the toolbar
> 2.  Specifying a startup service in the mapbook or in config.js doesn't
> seem to work.  And I can't find any place in the code where startup_service
> is referenced.
> So I added a few lines to main.js (at line 73):
>         var params = GeoMOOSE.getUrlParameters();
>         if(GeoMOOSE.isDefined(params.call)) {
>             var service_name = params.call;
>             delete params.call;
>             GeoMOOSE.startService(service_name, params, true);
> *        /*  --- new: --- */*
> *        if(GeoMOOSE.isDefined(CONFIGURATION['startup_service'])) { *
> *            var service_name = CONFIGURATION['startup_service'];*
> *            GeoMOOSE.startService(service_name, params, true);*
> while it does start the service in the config.js, but it has the same
> effect on the toolbar as specifying "?call=myservice" in the URL (it is
> disabled).
>   Is there something special I need to set to enable the toolbar after a
> startup service?
> Best Regards,
> Brent Fraser
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160329/3f700015/attachment.html>
More information about the Geomoose-users mailing list
