[Geomoose-users] using WFS-T
Brent Fraser bfraser at geoanalytic.com
Wed Mar 23 16:02:29 PDT 2016
Dan,
   Not an extension (hmm, that never occurred to me), just a few minor
code additions.  The mapbook would look like (actually I don't test for
the type):
<filter type="CQL"><![CDATA[image_id = 0 and reviewstatus_id<>24]]></filter>
and the new Geomoose API call would be used like:
             var filter = "reviewstatus_id<>24 and image_id="+id;
             GeoMOOSE.updateLayerFilter("Icebergs_WFS",filter);
and the code additions :
geomoose.js, line 228
     // BWF (Add feature filtering): updateLayerFilter (CQL)
     updateLayerFilter : function(layerName, CQL_text) {
Application.getMapSource(layerName).updateFilter(CQL_text);
Vector.js, line 266
         // BWF (Add feature filtering): CQL filter to restrict features
sent from server
         var filter_tag = mapbook_entry.getElementsByTagName('filter');
         if (filter_tag) {
             var filter_text =
OpenLayers.Util.getXmlNodeValue(filter_tag[0]);
             var filter = new OpenLayers.Filter.Logical();
             var format_CQL = new OpenLayers.Format.CQL();
             try {
                 filter = format_CQL.read(filter_text);
             } catch (err) {
//                GeoMOOSE.error('OpenLayers CQL parser is unable to
parse:'+filter_text);
             if (filter) {
                 this.filter = filter;
WFS.js, line 47:
             filter: this.filter,    // BWF (Add feature filtering)
WFS.js, line 88:
     /*  BWF: (Add feature filtering) CQL filter
     updateFilter: function(filter_text){
         try {
         } catch (err) {
         if (filter) {
             this._ol_layer.filter = this.filter;
             this._ol_layer.redraw({force: true});
             this._ol_layer.refresh({force: true});
Best Regards,
Brent Fraser
On 3/23/2016 4:04 PM, Dan Little wrote:
> Brent,
> I'd love to see the extension once it's done and look at including it
> in the 2.9 code.  My GeoMoose coding always comes in bursts and I'm
> bursting today...
> -Duck
> On Mon, Mar 21, 2016 at 12:23 PM, Brent Fraser
> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>     Jim,
>       I've changed my mind.  I've implemented CQL filters to allow me
>     to easily do things like:
>             <filter type="CQL">
>                 <![CDATA[reviewstatus_id<>24 and reviewstatus_id<>18
>     and image_id = 0]]>
>             </filter>
>     This requires only a minimal amount of code additions to Geomoose
>     as OpenLayers has a parser to convert CQL to its filter object.
>     And using the new API function would be like:
>           var filter = "reviewstatus_id<>24 and reviewstatus_id<>18
>     and image_id="+id;
>     I'll file an issue, and after some more testing, I'll do a pull
>     request.
>     Best Regards,
>     Brent Fraser
>     On 3/17/2016 9:45 AM, Brent Fraser wrote:
>>     Jim,
>>       Yes, this is my thinking as well.  The additional mapbook
>>     syntax is a bit of a question mark, but I guess that would depend
>>     on how much of the OpenLayers filter syntax we would want to support.
>>       For my purposes I've added to my wfs mapsource:
>>     <filter type="equal_to" property="image_id" value="204"/>
>>     but this will likely be too trivial for general cases since
>>     OpenLayers allows queries like:
>>                     filter: new OpenLayers.Filter.Logical({
>>                         type: OpenLayers.Filter.Logical.OR,
>>                         filters: [
>>                             new OpenLayers.Filter.Comparison({
>>                                 type:
>>     OpenLayers.Filter.Comparison.EQUAL_TO,
>>                                 property: "TYPE",
>>                                 value: "highway"
>>                                 type:
>>                                 property: "TYPE",
>>                                 value: "road"
>>     Not impossible but might take a little bit of design.
>>     Another possibility would be be to use CQL and let the user
>>     specify the CQL text then have OpenLayers parse it.  I've run
>>     across references to this in my Googling, but I don't know much
>>     about it.
>>     As for the Geomoose code, I'm hacking together some code to do:
>>     from my extension code:
>>         params['image_id'] = id;
>>     GeoMOOSE.updateLayerFilter("Icebergs_WFS",params);
>>     where geomoose.js has
>>         updateLayerFilter : function(layerName, paramObject) {
>>     Application.getMapSource(layerName).updateFilter(paramObject);
>>     Now I have to do the rest of the coding...
>>     Best Regards,
>>     Brent Fraser
>>     On 3/17/2016 9:03 AM, James Klassen wrote:
>>>     I'm not sure this will work with the WFS layer, but this sounds
>>>     like something that GeoMOOSE.updateLayerParameters() would
>>>     accomplish for WMS.
>>>     Currently (and subject to change between versions), you can get
>>>     at the underlying OpenLayers layer object with:
>>>     Application.getMapSource('mapbook/path')._ol_layer
>>>     This is something you could call from a script return from a
>>>     service or from a custom tab.
>>>     Having to dig in the internals in an unsupported way is what
>>>     usually prompts me to suggest additions to GeoMOOSE.*
>>>     Generally, I just do what I need to get done and after it shakes
>>>     out for a bit figure out how it could be done more generically.
>>>     Jim
>>>     On Tue, Mar 15, 2016 at 9:58 PM, Brent Fraser
>>>         Hey Eli,
>>>           The filtering is for visual purposes: since images from
>>>         different dates may be in the same location I want to see
>>>         only those polygons related to the image being shown.
>>>           My particular use-case is such that there will never be
>>>         very many polygons served via WFS at once. but I do have
>>>         some performance concerns in general. Fortunately
>>>         Geomoose/OpenLayers sends a bounding box filter based on the
>>>         display window so that will tend to minimize the problem.
>>>           I've hard-coded an OpenLayers attribute filter in WFS.js
>>>         for testing purposes:
>>>                 this._ol_layer = new
>>>         OpenLayers.Layer.Vector(this.title, {
>>>                     strategies: strategies,
>>>                     projection: this.srsName,
>>>                     styleMap : this.style_map,
>>>                     visibility: false,
>>>         *            filter: new OpenLayers.Filter.Comparison({ //BWF**
>>>         **                type: OpenLayers.Filter.Comparison.EQUAL_TO,**
>>>         **property: "image_id",**
>>>         **                value: "204"**
>>>         **            proto*col: new OpenLayers.Protocol.WFS({
>>>                         version: '1.1.0',
>>>                         srsName: this.srsName,
>>>                         url: this.url,
>>>                         featureNS: this.featureNS,
>>>                         featurePrefix: this.featurePrefix,
>>>                         featureType: this.featureType,
>>>                         geometryName: this.featureGeometryName,
>>>                         schema: this.featureSchema
>>>         and it works fine (the above code causes only those polygons
>>>         digitized from image 204 to be shown).  Now I need to hack
>>>         in some code to change the filter value when the user
>>>         selects a different image.  While it will be ok for my
>>>         project, it would be nice to come up with a more general
>>>         approach.  Maybe I'll get some inspiration while hacking...
>>>         Best Regards,
>>>         Brent Fraser
>>>         On 3/15/2016 5:57 PM, Eli Adam wrote:
>>>>         Hi Brent,
>>>>         On Tue, Mar 15, 2016 at 7:38 AM, Brent Fraser<bfraser at geoanalytic.com> <mailto:bfraser at geoanalytic.com>  wrote:
>>>>>         Hi All,
>>>>>            Now that I've configured my Geomoose demo to do WFS-T, I need to think
>>>>>         about how to use it in my old Geomoose v2.4  Ice Digitizing application.
>>>>         Cool, good to hear that it is working.
>>>>>            That application grouped digitized polygons by "image_id" (representing
>>>>>         the Landsat image used as a backdrop).  There are hundreds of images and
>>>>>         thousands of polygons in the system and when the user selected an image,
>>>>>         Geomoose passed the image_id to mapserver to do a substitution in the
>>>>>         mapfile SQL so only those polygons related to that image were displayed (and
>>>>>         available for edits etc).  That worked great.
>>>>         Is filtering for visual purposes so that you can see what is going on?
>>>>           Or is filtering for performance and browser limits?  Did you try
>>>>         solution 0 which is to do no filtering and see if it works?
>>>>>         How do I do the same thing with Geomoose v2.8 for my app?  Some possible
>>>>>         "solutions" (I like #3):
>>>>>         1.  Convert the old 2.4 vector editing system to a user extension and use it
>>>>>         instead of WFS-T
>>>>>                  - a lot of work, uses deprecated code, and no benefit to the
>>>>>         Geomoose community
>>>>>         or
>>>>>         2. Create a layer per image_id in the TingyOWS config.xml file and have
>>>>>         Geomoose switch layer name when the user selects the image.
>>>>>              - as images get added to the system the config.xml file must be updated
>>>>>         (could be automated, but clunky)
>>>>>              - each layer would point to a table in the database which would make the
>>>>>         database ugly
>>>>>         (hundreds of tables).  I might be able to use views instead of tables to
>>>>>         make it slightly less ugly, but TinyOWS might not do inserts into a view.
>>>>>         Dunno about that.
>>>>>              - could be some limitations on the number of layers in the config.xml
>>>>>         file (or performance issues?).
>>>>>         or
>>>>>         3.  Add functionality to Geomoose to accept attribute filters in the mapbook
>>>>>         and pass the filters to the OpenLayers definition.
>>>>>              - adds complexity to the mapbook syntax (so more documentation, testing,
>>>>>         maint., etc).
>>>>>              - the logic may be similar to the  mapbook's search/query mechanism of
>>>>>         specifying input types of layer,template,fieldname,comparitor,value so maybe
>>>>>         some of the code could be used.
>>>>         This sounds like an option worth exploring and may have other general
>>>>         applicaitons.
>>>>>         or
>>>>>         4.  Other?
>>>>         My ideas are sort of light on this one, hopefully others have further ideas.
>>>>         Best regards, Eli
>>>>>         Thanks for any input!
>>>>>         Best Regards,
>>>>>         Brent Fraser
>>>>>         _______________________________________________
>>>>>         Geomoose-users mailing list
>>>>>         Geomoose-users at lists.osgeo.org
>>>>>         <mailto:Geomoose-users at lists.osgeo.org>
>>>>>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160323/df321db8/attachment-0001.html>
More information about the Geomoose-users mailing list
