[Geomoose-users] using WFS-T
Dan Little theduckylittle at gmail.com
Wed Mar 23 16:50:35 PDT 2016
At some point, you'll need to get brave and do a pull request. For now,
I'll put merging this code on my to-do list.
On Mar 23, 2016 6:02 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
> Dan,
>   Not an extension (hmm, that never occurred to me), just a few minor code
> additions.  The mapbook would look like (actually I don't test for the
> type):
> <filter type="CQL"><![CDATA[image_id = 0 and
> reviewstatus_id<>24]]></filter>
> and the new Geomoose API call would be used like:
>             var filter = "reviewstatus_id<>24 and image_id="+id;
>             GeoMOOSE.updateLayerFilter("Icebergs_WFS",filter);
> and the code additions :
> geomoose.js, line 228
>     // BWF (Add feature filtering): updateLayerFilter (CQL)
>     updateLayerFilter : function(layerName, CQL_text) {
>         Application.getMapSource(layerName).updateFilter(CQL_text);
> Vector.js, line 266
>         // BWF (Add feature filtering): CQL filter to restrict features
> sent from server
>         var filter_tag = mapbook_entry.getElementsByTagName('filter');
>         if (filter_tag) {
>             var filter_text =
> OpenLayers.Util.getXmlNodeValue(filter_tag[0]);
>             var filter = new OpenLayers.Filter.Logical();
>             var format_CQL = new OpenLayers.Format.CQL();
>             try {
>                 filter = format_CQL.read(filter_text);
>             } catch (err) {
> //                GeoMOOSE.error('OpenLayers CQL parser is unable to
> parse:'+filter_text);
>             if (filter) {
>                 this.filter = filter;
> WFS.js, line 47:
>             filter: this.filter,    // BWF (Add feature filtering)
> WFS.js, line 88:
>     /*  BWF: (Add feature filtering) CQL filter
>     updateFilter: function(filter_text){
>         try {
>         } catch (err) {
>         if (filter) {
>             this._ol_layer.filter = this.filter;
>             this._ol_layer.redraw({force: true});
>             this._ol_layer.refresh({force: true});
> Best Regards,
> Brent Fraser
> On 3/23/2016 4:04 PM, Dan Little wrote:
> Brent,
> I'd love to see the extension once it's done and look at including it in
> the 2.9 code.  My GeoMoose coding always comes in bursts and I'm bursting
> today...
> -Duck
> On Mon, Mar 21, 2016 at 12:23 PM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Jim,
>>   I've changed my mind.  I've implemented CQL filters to allow me to
>> easily do things like:
>>         <filter type="CQL">
>>             <![CDATA[reviewstatus_id<>24 and reviewstatus_id<>18 and image_id
>> = 0]]>
>>         </filter>
>> This requires only a minimal amount of code additions to Geomoose as
>> OpenLayers has a parser to convert CQL to its filter object.
>> And using the new API function would be like:
>>       var filter = "reviewstatus_id<>24 and reviewstatus_id<>18 and
>> image_id="+id;
>> I'll file an issue, and after some more testing, I'll do a pull request.
>> Best Regards,
>> Brent Fraser
>> On 3/17/2016 9:45 AM, Brent Fraser wrote:
>> Jim,
>>   Yes, this is my thinking as well.  The additional mapbook syntax is a
>> bit of a question mark, but I guess that would depend on how much of the
>> OpenLayers filter syntax we would want to support.
>>   For my purposes I've added to my wfs mapsource:
>>             <filter type="equal_to" property="image_id" value="204"/>
>> but this will likely be too trivial for general cases since OpenLayers
>> allows queries like:
>>                 filter: new OpenLayers.Filter.Logical({
>>                     type: OpenLayers.Filter.Logical.OR,
>>                     filters: [
>>                         new OpenLayers.Filter.Comparison({
>>                             type: OpenLayers.Filter.Comparison.EQUAL_TO,
>>                             property: "TYPE",
>>                             value: "highway"
>>                             property: "TYPE",
>>                             value: "road"
>> Not impossible but might take a little bit of design.
>> Another possibility would be be to use CQL and let the user specify the
>> CQL text then have OpenLayers parse it.  I've run across references to this
>> in my Googling, but I don't know much about it.
>> As for the Geomoose code, I'm hacking together some code to do:
>> from my extension code:
>>     params['image_id'] = id;
>>     GeoMOOSE.updateLayerFilter("Icebergs_WFS",params);
>> where geomoose.js has
>>     updateLayerFilter : function(layerName, paramObject) {
>>         Application.getMapSource(layerName).updateFilter(paramObject);
>> Now I have to do the rest of the coding...
>> Best Regards,
>> Brent Fraser
>> On 3/17/2016 9:03 AM, James Klassen wrote:
>> I'm not sure this will work with the WFS layer, but this sounds like
>> something that GeoMOOSE.updateLayerParameters() would accomplish for WMS.
>> Currently (and subject to change between versions), you can get at the
>> underlying OpenLayers layer object with:
>> Application.getMapSource('mapbook/path')._ol_layer
>> This is something you could call from a script return from a service or
>> from a custom tab.
>> Having to dig in the internals in an unsupported way is what usually
>> prompts me to suggest additions to GeoMOOSE.*  Generally, I just do what I
>> need to get done and after it shakes out for a bit figure out how it could
>> be done more generically.
>> Jim
>> On Tue, Mar 15, 2016 at 9:58 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Hey Eli,
>>>   The filtering is for visual purposes: since images from different
>>> dates may be in the same location I want to see only those polygons related
>>> to the image being shown.
>>>   My particular use-case is such that there will never be very many
>>> polygons served via WFS at once. but I do have some performance concerns in
>>> general.  Fortunately Geomoose/OpenLayers sends a bounding box filter based
>>> on the display window so that will tend to minimize the problem.
>>>   I've hard-coded an OpenLayers attribute filter in WFS.js for testing
>>> purposes:
>>>         this._ol_layer = new OpenLayers.Layer.Vector(this.title, {
>>>             strategies: strategies,
>>>             projection: this.srsName,
>>>             styleMap : this.style_map,
>>>             visibility: false,
>>> *            filter: new OpenLayers.Filter.Comparison({         //BWF*
>>> *                type: OpenLayers.Filter.Comparison.EQUAL_TO,*
>>> *                property: "image_id",*
>>> *                value: "204"*
>>> *            proto*col: new OpenLayers.Protocol.WFS({
>>>                 version: '1.1.0',
>>>                 srsName: this.srsName,
>>>                 url: this.url,
>>>                 featureNS: this.featureNS,
>>>                 featurePrefix: this.featurePrefix,
>>>                 featureType: this.featureType,
>>>                 geometryName: this.featureGeometryName,
>>>                 schema: this.featureSchema
>>> and it works fine (the above code causes only those polygons digitized
>>> from image 204 to be shown).  Now I need to hack in some code to change the
>>> filter value when the user selects a different image.  While it will be ok
>>> for my project, it would be nice to come up with a more general approach.
>>> Maybe I'll get some inspiration while hacking...
>>> Best Regards,
>>> Brent Fraser
>>> On 3/15/2016 5:57 PM, Eli Adam wrote:
>>> Hi Brent,
>>> On Tue, Mar 15, 2016 at 7:38 AM, Brent Fraser <bfraser at geoanalytic.com> <bfraser at geoanalytic.com> wrote:
>>> Hi All,
>>>   Now that I've configured my Geomoose demo to do WFS-T, I need to think
>>> about how to use it in my old Geomoose v2.4  Ice Digitizing application.
>>> Cool, good to hear that it is working.
>>>   That application grouped digitized polygons by "image_id" (representing
>>> the Landsat image used as a backdrop).  There are hundreds of images and
>>> thousands of polygons in the system and when the user selected an image,
>>> Geomoose passed the image_id to mapserver to do a substitution in the
>>> mapfile SQL so only those polygons related to that image were displayed (and
>>> available for edits etc).  That worked great.
>>> Is filtering for visual purposes so that you can see what is going on?
>>>  Or is filtering for performance and browser limits?  Did you try
>>> solution 0 which is to do no filtering and see if it works?
>>> How do I do the same thing with Geomoose v2.8 for my app?  Some possible
>>> "solutions" (I like #3):
>>> 1.  Convert the old 2.4 vector editing system to a user extension and use it
>>> instead of WFS-T
>>>         - a lot of work, uses deprecated code, and no benefit to the
>>> Geomoose community
>>> or
>>> 2. Create a layer per image_id in the TingyOWS config.xml file and have
>>> Geomoose switch layer name when the user selects the image.
>>>     - as images get added to the system the config.xml file must be updated
>>> (could be automated, but clunky)
>>>     - each layer would point to a table in the database which would make the
>>> database ugly
>>> (hundreds of tables).  I might be able to use views instead of tables to
>>> make it slightly less ugly, but TinyOWS might not do inserts into a view.
>>> Dunno about that.
>>>     - could be some limitations on the number of layers in the config.xml
>>> file (or performance issues?).
>>> or
>>> 3.  Add functionality to Geomoose to accept attribute filters in the mapbook
>>> and pass the filters to the OpenLayers definition.
>>>     - adds complexity to the mapbook syntax (so more documentation, testing,
>>> maint., etc).
>>>     - the logic may be similar to the  mapbook's search/query mechanism of
>>> specifying input types of layer,template,fieldname,comparitor,value so maybe
>>> some of the code could be used.
>>> This sounds like an option worth exploring and may have other general
>>> applicaitons.
>>> or
>>> 4.  Other?
>>> My ideas are sort of light on this one, hopefully others have further ideas.
>>> Best regards, Eli
>>> Thanks for any input!
>>> Best Regards,
>>> Brent Fraser
>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160323/57144534/attachment-0001.html>
More information about the Geomoose-users mailing list
