[Geomoose-users] using WFS-T
Dan Little theduckylittle at gmail.com
Tue Mar 29 13:35:18 PDT 2016
Ok Brent, y'all got more code to test:
https://github.com/geomoose/geomoose/issues/121
On Wed, Mar 23, 2016 at 6:50 PM, Dan Little <theduckylittle at gmail.com>
wrote:
> At some point, you'll need to get brave and do a pull request. For now,
> I'll put merging this code on my to-do list.
> On Mar 23, 2016 6:02 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
>> Dan,
>>   Not an extension (hmm, that never occurred to me), just a few minor
>> code additions.  The mapbook would look like (actually I don't test for the
>> type):
>> <filter type="CQL"><![CDATA[image_id = 0 and
>> reviewstatus_id<>24]]></filter>
>> and the new Geomoose API call would be used like:
>>             var filter = "reviewstatus_id<>24 and image_id="+id;
>>             GeoMOOSE.updateLayerFilter("Icebergs_WFS",filter);
>> and the code additions :
>> geomoose.js, line 228
>>     // BWF (Add feature filtering): updateLayerFilter (CQL)
>>     updateLayerFilter : function(layerName, CQL_text) {
>>         Application.getMapSource(layerName).updateFilter(CQL_text);
>> Vector.js, line 266
>>         // BWF (Add feature filtering): CQL filter to restrict features
>> sent from server
>>         var filter_tag = mapbook_entry.getElementsByTagName('filter');
>>         if (filter_tag) {
>>             var filter_text =
>> OpenLayers.Util.getXmlNodeValue(filter_tag[0]);
>>             var filter = new OpenLayers.Filter.Logical();
>>             var format_CQL = new OpenLayers.Format.CQL();
>>             try {
>>                 filter = format_CQL.read(filter_text);
>>             } catch (err) {
>> //                GeoMOOSE.error('OpenLayers CQL parser is unable to
>> parse:'+filter_text);
>>             if (filter) {
>>                 this.filter = filter;
>> WFS.js, line 47:
>>             filter: this.filter,    // BWF (Add feature filtering)
>> WFS.js, line 88:
>>     /*  BWF: (Add feature filtering) CQL filter
>>     updateFilter: function(filter_text){
>>         try {
>>         } catch (err) {
>>         if (filter) {
>>             this._ol_layer.filter = this.filter;
>>             this._ol_layer.redraw({force: true});
>>             this._ol_layer.refresh({force: true});
>> Best Regards,
>> Brent Fraser
>> On 3/23/2016 4:04 PM, Dan Little wrote:
>> Brent,
>> I'd love to see the extension once it's done and look at including it in
>> the 2.9 code.  My GeoMoose coding always comes in bursts and I'm bursting
>> today...
>> -Duck
>> On Mon, Mar 21, 2016 at 12:23 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Jim,
>>>   I've changed my mind.  I've implemented CQL filters to allow me to
>>> easily do things like:
>>>         <filter type="CQL">
>>>             <![CDATA[reviewstatus_id<>24 and reviewstatus_id<>18 and image_id
>>> = 0]]>
>>>         </filter>
>>> This requires only a minimal amount of code additions to Geomoose as
>>> OpenLayers has a parser to convert CQL to its filter object.
>>> And using the new API function would be like:
>>>       var filter = "reviewstatus_id<>24 and reviewstatus_id<>18 and
>>> image_id="+id;
>>> I'll file an issue, and after some more testing, I'll do a pull request.
>>> Best Regards,
>>> Brent Fraser
>>> On 3/17/2016 9:45 AM, Brent Fraser wrote:
>>> Jim,
>>>   Yes, this is my thinking as well.  The additional mapbook syntax is a
>>> bit of a question mark, but I guess that would depend on how much of the
>>> OpenLayers filter syntax we would want to support.
>>>   For my purposes I've added to my wfs mapsource:
>>>             <filter type="equal_to" property="image_id" value="204"/>
>>> but this will likely be too trivial for general cases since OpenLayers
>>> allows queries like:
>>>                 filter: new OpenLayers.Filter.Logical({
>>>                     type: OpenLayers.Filter.Logical.OR,
>>>                     filters: [
>>>                         new OpenLayers.Filter.Comparison({
>>>                             type: OpenLayers.Filter.Comparison.EQUAL_TO,
>>>                             property: "TYPE",
>>>                             value: "highway"
>>>                             property: "TYPE",
>>>                             value: "road"
>>> Not impossible but might take a little bit of design.
>>> Another possibility would be be to use CQL and let the user specify the
>>> CQL text then have OpenLayers parse it.  I've run across references to this
>>> in my Googling, but I don't know much about it.
>>> As for the Geomoose code, I'm hacking together some code to do:
>>> from my extension code:
>>>     params['image_id'] = id;
>>>     GeoMOOSE.updateLayerFilter("Icebergs_WFS",params);
>>> where geomoose.js has
>>>     updateLayerFilter : function(layerName, paramObject) {
>>>         Application.getMapSource(layerName).updateFilter(paramObject);
>>> Now I have to do the rest of the coding...
>>> Best Regards,
>>> Brent Fraser
>>> On 3/17/2016 9:03 AM, James Klassen wrote:
>>> I'm not sure this will work with the WFS layer, but this sounds like
>>> something that GeoMOOSE.updateLayerParameters() would accomplish for WMS.
>>> Currently (and subject to change between versions), you can get at the
>>> underlying OpenLayers layer object with:
>>> Application.getMapSource('mapbook/path')._ol_layer
>>> This is something you could call from a script return from a service or
>>> from a custom tab.
>>> Having to dig in the internals in an unsupported way is what usually
>>> prompts me to suggest additions to GeoMOOSE.*  Generally, I just do what I
>>> need to get done and after it shakes out for a bit figure out how it could
>>> be done more generically.
>>> Jim
>>> On Tue, Mar 15, 2016 at 9:58 PM, Brent Fraser <
>>> <bfraser at geoanalytic.com>bfraser at geoanalytic.com> wrote:
>>>> Hey Eli,
>>>>   The filtering is for visual purposes: since images from different
>>>> dates may be in the same location I want to see only those polygons related
>>>> to the image being shown.
>>>>   My particular use-case is such that there will never be very many
>>>> polygons served via WFS at once. but I do have some performance concerns in
>>>> general.  Fortunately Geomoose/OpenLayers sends a bounding box filter based
>>>> on the display window so that will tend to minimize the problem.
>>>>   I've hard-coded an OpenLayers attribute filter in WFS.js for testing
>>>> purposes:
>>>>         this._ol_layer = new OpenLayers.Layer.Vector(this.title, {
>>>>             strategies: strategies,
>>>>             projection: this.srsName,
>>>>             styleMap : this.style_map,
>>>>             visibility: false,
>>>> *            filter: new OpenLayers.Filter.Comparison({         //BWF*
>>>> *                type: OpenLayers.Filter.Comparison.EQUAL_TO,*
>>>> *                property: "image_id",*
>>>> *                value: "204"*
>>>> *            proto*col: new OpenLayers.Protocol.WFS({
>>>>                 version: '1.1.0',
>>>>                 srsName: this.srsName,
>>>>                 url: this.url,
>>>>                 featureNS: this.featureNS,
>>>>                 featurePrefix: this.featurePrefix,
>>>>                 featureType: this.featureType,
>>>>                 geometryName: this.featureGeometryName,
>>>>                 schema: this.featureSchema
>>>> and it works fine (the above code causes only those polygons digitized
>>>> from image 204 to be shown).  Now I need to hack in some code to change the
>>>> filter value when the user selects a different image.  While it will be ok
>>>> for my project, it would be nice to come up with a more general approach.
>>>> Maybe I'll get some inspiration while hacking...
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 3/15/2016 5:57 PM, Eli Adam wrote:
>>>> Hi Brent,
>>>> On Tue, Mar 15, 2016 at 7:38 AM, Brent Fraser <bfraser at geoanalytic.com> <bfraser at geoanalytic.com> wrote:
>>>> Hi All,
>>>>   Now that I've configured my Geomoose demo to do WFS-T, I need to think
>>>> about how to use it in my old Geomoose v2.4  Ice Digitizing application.
>>>> Cool, good to hear that it is working.
>>>>   That application grouped digitized polygons by "image_id" (representing
>>>> the Landsat image used as a backdrop).  There are hundreds of images and
>>>> thousands of polygons in the system and when the user selected an image,
>>>> Geomoose passed the image_id to mapserver to do a substitution in the
>>>> mapfile SQL so only those polygons related to that image were displayed (and
>>>> available for edits etc).  That worked great.
>>>> Is filtering for visual purposes so that you can see what is going on?
>>>>  Or is filtering for performance and browser limits?  Did you try
>>>> solution 0 which is to do no filtering and see if it works?
>>>> How do I do the same thing with Geomoose v2.8 for my app?  Some possible
>>>> "solutions" (I like #3):
>>>> 1.  Convert the old 2.4 vector editing system to a user extension and use it
>>>> instead of WFS-T
>>>>         - a lot of work, uses deprecated code, and no benefit to the
>>>> Geomoose community
>>>> or
>>>> 2. Create a layer per image_id in the TingyOWS config.xml file and have
>>>> Geomoose switch layer name when the user selects the image.
>>>>     - as images get added to the system the config.xml file must be updated
>>>> (could be automated, but clunky)
>>>>     - each layer would point to a table in the database which would make the
>>>> database ugly
>>>> (hundreds of tables).  I might be able to use views instead of tables to
>>>> make it slightly less ugly, but TinyOWS might not do inserts into a view.
>>>> Dunno about that.
>>>>     - could be some limitations on the number of layers in the config.xml
>>>> file (or performance issues?).
>>>> or
>>>> 3.  Add functionality to Geomoose to accept attribute filters in the mapbook
>>>> and pass the filters to the OpenLayers definition.
>>>>     - adds complexity to the mapbook syntax (so more documentation, testing,
>>>> maint., etc).
>>>>     - the logic may be similar to the  mapbook's search/query mechanism of
>>>> specifying input types of layer,template,fieldname,comparitor,value so maybe
>>>> some of the code could be used.
>>>> This sounds like an option worth exploring and may have other general
>>>> applicaitons.
>>>> or
>>>> 4.  Other?
>>>> My ideas are sort of light on this one, hopefully others have further ideas.
>>>> Best regards, Eli
>>>> Thanks for any input!
>>>> Best Regards,
>>>> Brent Fraser
>>>> _______________________________________________
>>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160329/51938a55/attachment-0001.html>
More information about the Geomoose-users mailing list
