[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
    Brent Fraser
    bfraser at geoanalytic.com
    Mon Mar 13 16:49:34 PDT 2017
Mark,
   Your SRS looks special.  Here are some map file settings I use to
debug SRS problems:
  CONFIG "PROJ_LIB" "\ms4w\proj\nad"
  CONFIG "CPL_DEBUG" "ON"
  CONFIG "PROJ_DEBUG" "ON"
Best Regards,
Brent Fraser
On 3/13/2017 1:36 PM, Mark Volz wrote:
> Hello,
> I am still having issues trying to get the feature report and buffer
> on selected features functionality to work on my map.  I am
> specifically wondering if anyone has had any success using a
> projection other than EPSG:3857.
> Buffers:
> At GeoMOOSE 2.9.2 the select feature function uses query.php.  However
> on an older 2.6 application I noticed the select feature function used
> select.php instead.
> *Do I need select.php to draw buffers in the select feature function?
> *select.php attempts to create a spatial lite .db file.  However, I
> cannot get this file to open in Mapserver
> *I cannot get the mailing labels to work using select.php
> Feature Reports:
> I am also having issues with the feature report functionality.  Is the
> feature report dependent on a certain projection?
> Anyways, if anyone has had any luck configuring GM 2.9.2 with a
> different projection please let me know.
> Thank You!
> Sincerely,
> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170313/48ad6284/attachment.html>
More information about the Geomoose-users
