[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Dan Little
theduckylittle at gmail.com
Tue Mar 14 08:21:48 PDT 2017
2.9.X does not use select.php any longer. All of the querying
functionality has been moved to query.php and the older scripts are left
there for historical reference only.
On Mon, Mar 13, 2017 at 6:49 PM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Mark,
> Your SRS looks special. Here are some map file settings I use to debug
> SRS problems:
> CONFIG "PROJ_LIB" "\ms4w\proj\nad"
> CONFIG "CPL_DEBUG" "ON"
> CONFIG "PROJ_DEBUG" "ON"
> Best Regards,
> Brent Fraser
> On 3/13/2017 1:36 PM, Mark Volz wrote:
> Hello,
> I am still having issues trying to get the feature report and buffer on
> selected features functionality to work on my map. I am specifically
> wondering if anyone has had any success using a projection other than
> EPSG:3857.
> Buffers:
> At GeoMOOSE 2.9.2 the select feature function uses query.php. However on
> an older 2.6 application I noticed the select feature function used
> select.php instead.
> *Do I need select.php to draw buffers in the select feature function?
> *select.php attempts to create a spatial lite .db file. However, I cannot
> get this file to open in Mapserver
> *I cannot get the mailing labels to work using select.php
> Feature Reports:
> I am also having issues with the feature report functionality. Is the
> feature report dependent on a certain projection?
> Anyways, if anyone has had any luck configuring GM 2.9.2 with a different
> projection please let me know.
> Thank You!
> Sincerely,
> Mark Volz
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170314/e5802485/attachment-0001.html>
More information about the Geomoose-users
