[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Mark Volz
MarkVolz at co.lyon.mn.us
Tue Mar 14 08:26:34 PDT 2017
Dan,
I will revert back to query.php. Out of curiosity select.php use to draw a polygon outline depicting the boundary of any buffer in the select features function. Should that still be working or has it been depreciated in query.php?
Thank You!
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
504 Fairgrounds Rd<https://www.google.com/maps/?daddr=504%20Fairgrounds%20Rd,%20Marshall,%20MN%2056258?z=6>
Marshall, MN 56258<https://www.google.com/maps/?daddr=504%20Fairgrounds%20Rd,%20Marshall,%20MN%2056258?z=6>
Ph: (507) 532-8218
Fax: (507) 532-8217
http://lyonco.org/
http://geomoose.lyonco.org/
From: Dan Little [mailto:theduckylittle at gmail.com]
Sent: Tuesday, March 14, 2017 10:22 AM
To: Brent Fraser <bfraser at geoanalytic.com>
Cc: Mark Volz <MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
2.9.X does not use select.php any longer. All of the querying functionality has been moved to query.php and the older scripts are left there for historical reference only.
On Mon, Mar 13, 2017 at 6:49 PM, Brent Fraser <bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>> wrote:
Mark,
Your SRS looks special. Here are some map file settings I use to debug SRS problems:
CONFIG "PROJ_LIB" "\ms4w\proj\nad"
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
Best Regards,
Brent Fraser
On 3/13/2017 1:36 PM, Mark Volz wrote:
Hello,
I am still having issues trying to get the feature report and buffer on selected features functionality to work on my map. I am specifically wondering if anyone has had any success using a projection other than EPSG:3857.
Buffers:
At GeoMOOSE 2.9.2 the select feature function uses query.php. However on an older 2.6 application I noticed the select feature function used select.php instead.
*Do I need select.php to draw buffers in the select feature function?
*select.php attempts to create a spatial lite .db file. However, I cannot get this file to open in Mapserver
*I cannot get the mailing labels to work using select.php
Feature Reports:
I am also having issues with the feature report functionality. Is the feature report dependent on a certain projection?
Anyways, if anyone has had any luck configuring GM 2.9.2 with a different projection please let me know.
Thank You!
Sincerely,
Mark Volz
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170314/6cd73f80/attachment-0001.html>
More information about the Geomoose-users
