[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Dan Little theduckylittle at gmail.com
Tue Mar 14 08:27:23 PDT 2017
*everything* should be going through query.php now.  We integrated all of
the logic there.
On Tue, Mar 14, 2017 at 10:26 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Dan,
> I will revert back to query.php.   Out of curiosity select.php use to draw
> a polygon outline depicting the boundary of any buffer in the select
> features function.  Should that still be working or has it been depreciated
> in query.php?
> Thank You!
> Sincerely,
> *Mark Volz, GISP*
> *Lyon County GIS Coordinator*
> 504 Fairgrounds Rd
> <https://www.google.com/maps/?daddr=504%20Fairgrounds%20Rd,%20Marshall,%20MN%2056258?z=6>
> Marshall, MN 56258
> Ph:  (507) 532-8218
> Fax: (507) 532-8217
> http://lyonco.org/
> http://geomoose.lyonco.org/
> *From:* Dan Little [mailto:theduckylittle at gmail.com]
> *Sent:* Tuesday, March 14, 2017 10:22 AM
> *To:* Brent Fraser <bfraser at geoanalytic.com>
> *Cc:* Mark Volz <MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Issues with buffer lines not displaying
> 2.9.X does not use select.php any longer.  All of the querying
> functionality has been moved to query.php and the older scripts are left
> there for historical reference only.
> On Mon, Mar 13, 2017 at 6:49 PM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
> Mark,
>   Your SRS looks special.  Here are some map file settings I use to debug
> SRS problems:
>  CONFIG "PROJ_LIB" "\ms4w\proj\nad"
>  CONFIG "CPL_DEBUG" "ON"
>  CONFIG "PROJ_DEBUG" "ON"
> Best Regards,
> Brent Fraser
> On 3/13/2017 1:36 PM, Mark Volz wrote:
> Hello,
> I am still having issues trying to get the feature report and buffer on
> selected features functionality to work on my map.  I am specifically
> wondering if anyone has had any success using a projection other than
> EPSG:3857.
> Buffers:
> At GeoMOOSE 2.9.2 the select feature function uses query.php.  However on
> an older 2.6 application I noticed the select feature function used
> select.php instead.
> *Do I need select.php to draw buffers in the select feature function?
> *select.php attempts to create a spatial lite .db file.  However, I cannot
> get this file to open in Mapserver
> *I cannot get the mailing labels to work using select.php
> Feature Reports:
> I am also having issues with the feature report functionality.  Is the
> feature report dependent on a certain projection?
> Anyways, if anyone has had any luck configuring GM 2.9.2 with a different
> projection please let me know.
> Thank You!
> Sincerely,
> Mark Volz
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170314/8e406638/attachment.html>
More information about the Geomoose-users mailing list
