[Geomoose-users] issue with printing in GM 2.6
TC Haddad tchaddad at gmail.com
Mon Mar 27 14:50:33 PDT 2017
Well with 2 sets of http:// you can't even reach the server, while with one
set I get an image back right away, so that could definitely be a problem.
Not sure where the double http:// could be coming from though...
On Mon, Mar 27, 2017 at 2:27 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I am having trouble printing in GeoMOOSE 2.6.  GeoMOOSE 2.6 reports that
> there is an error calling the server and it is unable to load
> php/print.php.  While I started my initial phase of debugging I had noticed
> that one of the layers has two sets of http:// in the url, which could be
> causing issues.  Anyways, I was just wondering if anyone has seen this
> behavior before.  Everything else on the site works fine.
> [27-Mar-2017 16:20:10 America/Chicago] GET IMAGE:
> http://geomoose.co.pipestone.mn.us/mapcache?SERVICE=WMS&
> VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.
> ogc.se_inimage&SRS=EPSG:103765&FORMAT=image/png&WIDTH=
> 1600&HEIGHT=1400&BBOX=500657.49514286,170830.153,501932.
> 03685714,171945.377&LAYERS=StandardBackground&
> TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=
> StandardBackground
> [27-Mar-2017 16:20:11 America/Chicago] GET IMAGE: http://http://
> geomoose.co.pipestone.mn.us/cgi-bin/mapserv.exe?SERVICE=WMS&
> ogc.se_inimage&SRS=EPSG:103765&FORMAT=image/png;bits=
> 8&WIDTH=1600&HEIGHT=1400&BBOX=500657.49514286,170830.153,
> 501932.03685714,171945.377&LAYERS=streams,rivers,lakes,
> PublicWildlifeAreas,StateParks,Ditches,railroads,parcels,roads,
> PointsOfInterest,BikeTrails&MAP=/ms4w/apps/PipestoneMOOSE26/maps//layers/
> county/AllLayers.map&TRANSPARENT=TRUE&SERVICE=WMS&
> VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=streams,rivers,
> lakes,PublicWildlifeAreas,StateParks,Ditches,railroads,parcels,roads,
> PointsOfInterest,BikeTrails&map=/ms4w/apps/PipestoneMOOSE26/maps//layers/
> <http://http:/geomoose.co.pipestone.mn.us/cgi-bin/mapserv.exe?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG:103765&FORMAT=image/png;bits=8&WIDTH=1600&HEIGHT=1400&BBOX=500657.49514286,170830.153,501932.03685714,171945.377&LAYERS=streams,rivers,lakes,PublicWildlifeAreas,StateParks,Ditches,railroads,parcels,roads,PointsOfInterest,BikeTrails&MAP=/ms4w/apps/PipestoneMOOSE26/maps//layers/county/AllLayers.map&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=streams,rivers,lakes,PublicWildlifeAreas,StateParks,Ditches,railroads,parcels,roads,PointsOfInterest,BikeTrails&map=/ms4w/apps/PipestoneMOOSE26/maps//layers/county/AllLayers.map>
> Thank You!
> Sincerely,
> *Mark Volz, GISP*
> *Lyon County GIS Coordinator*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170327/f562c68d/attachment.html>
More information about the Geomoose-users mailing list
