[Geomoose-users] experimenting with Geomoose 3
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Thu Oct 26 08:43:44 PDT 2017
Hi Brent,
One way to do it is through the URL.
The layers are now remembered there ( as well as bbox/scale):
https://demo.geomoose.org/master/desktop/#on=sketch/default;vector-parcels/big-money;pipelines/pipelines;parcels/parcels;parcels/parcels_points&loc=38.93151147928233;-10370006.407643707;5550786.452080398
Jim has done quite a bit of work with setting default settings for GeoMoose via Apache as well.  We have a default MapFile set up for example that has a set of default layers set to “on”.
I believe the Google basemapping has been a problem to work with recently without a Google Map Key, and it’s been purposely left out of the demo.
bobb
On Oct 26, 2017, at 9:35 AM, Brent Fraser <bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>> wrote:
Hey all,
I'm experimenting with map backgrounds in 3.0.
Is it possible to use Google maps as a background?
Is it possible to use radio buttons instead of check boxes?   I've tried using
    <group title="Backgrounds" expand="true" multiple="false">
but it doesn't work.
Can I set a background layer on by default (e.g. status="on")?
Thanks!
Best Regards,
Brent Fraser
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
"C makes it easy to shoot yourself in the foot; C++ makes it harder, but when you do, it blows away your whole leg."
- Bjarne Stroustrup
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20171026/c0c42ec3/attachment.html>
More information about the Geomoose-users mailing list
