[Geomoose-users] Customizing the Toolbar in GM3
Kevin Grootendorst kgrootendorst at gmail.com
Tue Aug 14 06:26:47 PDT 2018
Thanks Dan, it's been a while since I developed in GM and forgot where the
toolbars were.
To clarify, I wasn't working directly with geomoose.css, but rather a
renamed copy, but appreciate the reminder.
Kevin
On 14 August 2018 at 09:09, Dan Little <theduckylittle at gmail.com> wrote:
> *Do not* directly modify geomoose.css, when you upgrade you'll lose all
> your changes.
> Please checkout this guide from our docs:
> - https://geomoose.github.io/gm3/howto/style-the-toolbar.html
> To remove a tool completely, remove it from the mapbook's <toolbar> entry.
> On Tue, Aug 14, 2018 at 8:07 AM Kevin Grootendorst <
> kgrootendorst at gmail.com> wrote:
>> Greetings,
>> I'm using GM3.2.1, and had a couple questions regarding customizing the
>> toolbar
>> 1) In geomoose.css, I'm able to modify .toolbar .tool {} to change
>> colour, etc., but it seems the 'Search' tool appears different, using a
>> different top spacing, size and font.  See attached.  Why would the Search
>> tool behave this way? Are there additional properties specific to the
>> Search tool that need modification?
>> 2) in what file can I completely remove the search button, or any other
>> button, from the toolbar?
>> Thanks,
>> Kevin
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180814/9c3fde9c/attachment.html>
More information about the Geomoose-users mailing list
