[Geomoose-users] Customizing the Toolbar in GM3
Dan Little theduckylittle at gmail.com
Tue Aug 14 06:09:50 PDT 2018
*Do not* directly modify geomoose.css, when you upgrade you'll lose all
your changes.
Please checkout this guide from our docs:
- https://geomoose.github.io/gm3/howto/style-the-toolbar.html
To remove a tool completely, remove it from the mapbook's <toolbar> entry.
On Tue, Aug 14, 2018 at 8:07 AM Kevin Grootendorst <kgrootendorst at gmail.com>
wrote:
> Greetings,
> I'm using GM3.2.1, and had a couple questions regarding customizing the
> toolbar
> 1) In geomoose.css, I'm able to modify .toolbar .tool {} to change colour,
> etc., but it seems the 'Search' tool appears different, using a different
> top spacing, size and font.  See attached.  Why would the Search tool
> behave this way? Are there additional properties specific to the Search
> tool that need modification?
> 2) in what file can I completely remove the search button, or any other
> button, from the toolbar?
> Thanks,
> Kevin
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180814/43a94796/attachment-0001.html>
More information about the Geomoose-users mailing list
