[Geomoose-users] GM 2.9.3 projection issue. GeoMOOSE is requesting an invalid BBOX on reprojected air photos, search results are not highlighting
Mark Volz MarkVolz at co.lyon.mn.us
Thu Jun 28 13:24:59 PDT 2018
Hello,
I recently created 3 GeoMOOSE Applications each using similar, but separate coordinate systems.  Two of the applications are working fine.  One of the applications however is mostly working but is not highlighting search results, nor is it properly reprojecting air photos via MapServer.  These applications are all similar so I am struggling to find out how to fix the problem.
Here is what works:
*         XY, Lat, Long, and USNG coordinates work and appear to be accurate.
*         Mapserver Maps and WMS air photos in County Coordinates work.
*         Measurement distances appear to be accurate.
*         Links to outside mapping services such as Google, Pictometry work and are in the right spot.
Here is what does not work:
*         Search Result Highlights
*         Adding reprojected air photos using mapserver.
Error log:
[Thu Jun 28 15:19:07 2018].268000 msProjectRect(): Projection library error. All points failed to reproject.
[Thu Jun 28 15:19:07 2018].307000 msHTTPExecuteRequests(): HTTP request error. HTTP GET request failed with status 400 () for http://geoint.lmic.state.mn.us/cgi-bin/wms?LAYERS=fsa2013cir&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/jpeg&STYLES=&HEIGHT=902&VERSION=1.1.1&SRS=EPSG:26915&WIDTH=1615&BBOX=0,0,0,0&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
Just out of curiosity, would anyone know why GeoMOOSE will convert coordinates to USNG and latitude and longitude for services, but not accept reprojected map files?
Thanks
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
504 Fairgrounds Rd<https://www.google.com/maps/?daddr=504%20Fairgrounds%20Rd,%20Marshall,%20MN%2056258?z=6>
Marshall, MN 56258<https://www.google.com/maps/?daddr=504%20Fairgrounds%20Rd,%20Marshall,%20MN%2056258?z=6>
Ph:  (507) 532-8218
Fax: (507) 532-8217
http://lyonco.org/
http://geomoose.lyonco.org/
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180628/cbde4d1c/attachment.html>
More information about the Geomoose-users mailing list
