[Geomoose-users] GM 2.9.3 projection issue. GeoMOOSE is requesting an invalid BBOX on reprojected air photos, search results are not highlighting
Jim Klassen klassen.js at gmail.com
Thu Jun 28 13:57:36 PDT 2018
On 06/28/2018 03:24 PM, Mark Volz wrote:
> Just out of curiosity, would anyone know why GeoMOOSE will convert coordinates to USNG and latitude and longitude for services, but not accept reprojected map files?
Most likely because GeoMoose is configured correctly but MapServer isn't.
For all the things you said work, the coordinate conversion is done in GeoMoose JavaScript code.  However, MapServer is responsible for reprojecting the image from something the WMS server supports to the projection of the GeoMoose map.
More information about the Geomoose-users mailing list
