[Geomoose-users] Add a language to GeoMoose
flavio rigolon flavio.rigolon at gmail.com
Fri Dec 11 00:59:18 PST 2020
Hi Eli,
 thanks for the answer: this is my first time in Github and I've tried
to create a new issue with the it.json file. Hope it's ok.
Best regards, flavio
Il giorno lun 7 dic 2020 alle ore 15:29 Eli Adam
<eadam at co.lincoln.or.us> ha scritto:
> Hi Flavio,
> Adding additional languages is great!  Can you open a Github issue
> with it.json here, https://github.com/geomoose/gm3/issues?
> It looks like placement of the language file has come up before,
> https://github.com/geomoose/gm3/issues/544
> And maybe we should actively call for additional translations there too!
> Best regards, Eli
> On Sun, Nov 29, 2020 at 11:43 PM flavio rigolon
> <flavio.rigolon at gmail.com> wrote:
> > Hi all,
> >  I'm using GeoMoose 3.6.2 and I've added my own "it.json" (italian language).
> > The default languages are stored in
> > "/srv/geomoose/gm3-example/htdocs/geomoose/src/gm3/lang/" but
> > following the instruction [1] is implied but not explicitly said that
> > we have to copy the. json file in the "home" directory (i.e.
> > "/srv/geomoose/gm3-example/htdocs/desktop"). So, in my case I've set
> > the "app.js" file like this:
> > var app = new gm3.Application({
> > mapserver_url: CONFIG.mapserver_url,
> > mapfile_root: CONFIG.mapfile_root,
> > map: {
> > scaleLine: {
> > enabled: true,
> > //    units: 'imperial'
> > units: 'metric'
> > lang: {
> > it: './it.json',
> > and it works fine.
> > Is it the case of edit the page [1] to explicitly point where the
> > .json file must be? (I think there is also a trivial typo error in the
> > page title: "...langauge" should be "...language").
> > I've translated the .json file in italian; do you think it could be
> > share to give a base point for other italian users like the es.json
> > one for spanish?
> > my 2 cents
> > best regards
> > flavio
> > [1] https://geomoose.github.io/gm3/howto/add-a-language.html
> > /"\  ASCII Ribbon Campaign
> > \ /  Respect for low technology.
> >  X  Keep e-mail messages readable by any computer system.
> > / \  Keep it ASCII.
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geomoose-users
/ \  Keep it ASCII.
More information about the Geomoose-users mailing list
