[Geomoose-users] Add a language to GeoMoose
Eli Adam eadam at co.lincoln.or.us
Fri Dec 11 11:44:56 PST 2020
Thanks so much to Flavio for the Italian translation!  That has been
incorporated into the project and Italian will be an available
language after the next release.
Best regards, Eli
On Fri, Dec 11, 2020 at 12:59 AM flavio rigolon
<flavio.rigolon at gmail.com> wrote:
> Hi Eli,
>  thanks for the answer: this is my first time in Github and I've tried
> to create a new issue with the it.json file. Hope it's ok.
> Best regards, flavio
> Il giorno lun 7 dic 2020 alle ore 15:29 Eli Adam
> <eadam at co.lincoln.or.us> ha scritto:
> > Hi Flavio,
> > Adding additional languages is great!  Can you open a Github issue
> > with it.json here, https://github.com/geomoose/gm3/issues?
> > It looks like placement of the language file has come up before,
> > https://github.com/geomoose/gm3/issues/544
> > And maybe we should actively call for additional translations there too!
> > Best regards, Eli
> > On Sun, Nov 29, 2020 at 11:43 PM flavio rigolon
> > > Hi all,
> > >  I'm using GeoMoose 3.6.2 and I've added my own "it.json" (italian language).
> > > The default languages are stored in
> > > "/srv/geomoose/gm3-example/htdocs/geomoose/src/gm3/lang/" but
> > > following the instruction [1] is implied but not explicitly said that
> > > we have to copy the. json file in the "home" directory (i.e.
> > > "/srv/geomoose/gm3-example/htdocs/desktop"). So, in my case I've set
> > > the "app.js" file like this:
> > > var app = new gm3.Application({
> > > mapserver_url: CONFIG.mapserver_url,
> > > mapfile_root: CONFIG.mapfile_root,
> > > map: {
> > > scaleLine: {
> > > enabled: true,
> > > //    units: 'imperial'
> > > units: 'metric'
> > > lang: {
> > > it: './it.json',
> > > and it works fine.
> > > Is it the case of edit the page [1] to explicitly point where the
> > > .json file must be? (I think there is also a trivial typo error in the
> > > page title: "...langauge" should be "...language").
> > > I've translated the .json file in italian; do you think it could be
> > > share to give a base point for other italian users like the es.json
> > > one for spanish?
> > > my 2 cents
> > > best regards
> > > flavio
> > > [1] https://geomoose.github.io/gm3/howto/add-a-language.html
> > > /"\  ASCII Ribbon Campaign
> > > \ /  Respect for low technology.
> > >  X  Keep e-mail messages readable by any computer system.
> > > / \  Keep it ASCII.
> > > _______________________________________________
> > > Geomoose-users mailing list
> > > Geomoose-users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
> / \  Keep it ASCII.
More information about the Geomoose-users mailing list
