[Geomoose-users] GeoMoose 3 - Select
Christopher Hughes chughes at co.lincoln.or.us
Mon Jan 27 15:27:33 PST 2020
Thanks for the feedback.
I'm having trouble replicating this. I'm trying to modify the demo's select
to test it and I'm not noticing any difference in the select tool.
Demo:
    app.registerService('select', SelectService, {
        // set the default layer
        defaultLayer: 'vector-parcels/parcels',
My Attempt:
        // remove the layer select
        inputs: [{
            type: 'hidden',
            default: 'vector-parcels/parcels'
The only change I'm noticing is that with this syntax, turning on autoGo
and removing the select options incompatible with autoGo no longer works.
Any suggestions?
Thanks,
Chris
On Sun, Jan 26, 2020 at 1:24 PM Dan Little <theduckylittle at gmail.com> wrote:
> This should be settable in app.js:
>     app.registerService('my-other-select', SelectService, {
>         inputs: [{
>             type: 'hidden',
>             default: 'source/layer'
> This change removes the Select input and makes it a fixed field. You can
> also specify that as a select with a fixed list of layers.
> On Fri, Jan 10, 2020 at 3:35 PM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
>> For geomoose 3, is there a way to specify which layers you can select
>> rather than just setting
>> the default layer and being able to select all layers you've set to be
>> selectable? I'd like to create
>> a select tool for each of the layers I want to select (like you can for
>> searches), but if I do that now
>> you'd still be able to switch to a different layer in the tool.
>> Relatedly, is there a way to remove the
>> 'Select from' dropdown box so it just uses the default layer you set in
>> the service?
>> Thanks,
>> Chris
>> Chris Hughes
>> GIS Analyst
>> Lincoln County Surveyor Department
>> 880 NE 7th St. l Newport, OR 97365
>> Tel: (541) 574 1283
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200127/ca350a7d/attachment.html>
More information about the Geomoose-users mailing list
