[Geomoose-users] GeoMoose 3 - Select
Christopher Hughes chughes at co.lincoln.or.us
Tue Jan 28 11:18:49 PST 2020
Thanks for these fixes! I've added these and now it looks like it's working
(almost) as expected.
My only question is what is the 'name: 'layer'' parameter supposed to do?
Adding or removing
it doesn't appear to change how the service works or looks, so I'm not
entirely sure I've configured
it correctly. I was hoping it would add a subheader or something so that
users know what dataset
they're querying. (The main reason I'm trying to do this is because for
some users breaking apart
the select into different tools may be more straightforward than a
drop-down menu).
Thanks,
Chris
On Mon, Jan 27, 2020 at 6:17 PM Dan Little <theduckylittle at gmail.com> wrote:
> I messed up two things:
> 1. It should be "fields" not "inputs".
> 2. We have not properly implemented hidden fields.
> Here is the fix for 1:
>     app.registerService('select', SelectService, {
>         // set the default layer
>         defaultLayer: 'vector-parcels/parcels',
>         fields: [{
>             type: 'hidden',
>             default: 'vector-parcels/parcels'
> And the fix for 2:
> - https://github.com/geomoose/gm3/pull/461
> On Mon, Jan 27, 2020 at 5:27 PM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
>> Thanks for the feedback.
>> I'm having trouble replicating this. I'm trying to modify the demo's
>> select to test it and I'm not noticing any difference in the select tool.
>> Demo:
>> My Attempt:
>>         // remove the layer select
>>         inputs: [{
>>             type: 'hidden',
>> The only change I'm noticing is that with this syntax, turning on autoGo
>> and removing the select options incompatible with autoGo no longer works.
>> Any suggestions?
>> Thanks,
>> Chris
>> On Sun, Jan 26, 2020 at 1:24 PM Dan Little <theduckylittle at gmail.com>
>> wrote:
>>> This should be settable in app.js:
>>>     app.registerService('my-other-select', SelectService, {
>>>         inputs: [{
>>>             type: 'hidden',
>>>             default: 'source/layer'
>>> This change removes the Select input and makes it a fixed field. You can
>>> also specify that as a select with a fixed list of layers.
>>> On Fri, Jan 10, 2020 at 3:35 PM Christopher Hughes <
>>>> For geomoose 3, is there a way to specify which layers you can select
>>>> rather than just setting
>>>> the default layer and being able to select all layers you've set to be
>>>> selectable? I'd like to create
>>>> a select tool for each of the layers I want to select (like you can for
>>>> searches), but if I do that now
>>>> you'd still be able to switch to a different layer in the tool.
>>>> Relatedly, is there a way to remove the
>>>> 'Select from' dropdown box so it just uses the default layer you set in
>>>> the service?
>>>> Thanks,
>>>> Chris
>>>> Chris Hughes
>>>> GIS Analyst
>>>> Lincoln County Surveyor Department
>>>> 880 NE 7th St. l Newport, OR 97365
>>>> Tel: (541) 574 1283
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Chris Hughes
>> GIS Analyst
>> Tel: (541) 574 1283
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200128/29f96da8/attachment-0001.html>
More information about the Geomoose-users mailing list
