[Geomoose-users] Install Geomoose
Dan Little theduckylittle at gmail.com
Thu Jan 30 08:34:42 PST 2020
Hello Lara!
Due to some internal limitations with OpenLayers the GeoMoose basemap is in
EPSG:3857 (Web Mercator). Which means all of the coordinates fed to
GeoMoose are in either EPSG:4326 or EPSG:3857.
Ensure the initial view settings are in EPSG:3857 and it might be helpful
to configure you mapfiles and preview them in QGIS to make sure they are
configured to be served in EPSG:3857.
Thank you!
On Thu, Jan 30, 2020 at 8:24 AM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> On 2020-01-30 10:03 a.m., LARA wrote:
> > Winodws Server 2016. MS4W 2019-12-19. Apache 2.4. Mapserver 5.6.
> > Geomoose 3.4.0. Thanks in advance
> Hi Lara,
> I'm glad that MS4W has helped you!  Please note that you mention the
> above version of MS4W, but it actually contains MapServer 7.6.0-dev
> You can confirm this by opening a Command Window, and executing:
>    cd c:/ms4w
>    setenv.bat
>    mapserv -v
> Thank you for using MS4W.
> "MS4W: open doors as well as windows"
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200130/4300eeb8/attachment.html>
More information about the Geomoose-users mailing list
