[Geomoose-users] GeoMoose 3 - Speed
James Klassen klassen.js at gmail.com
Fri Jan 31 15:36:13 PST 2020
How are you loading the data in GeoMoose 3?  In GeoMoose 2 I'm guessing it
was via WMS.
Where are you seeing the bottleneck?  The web service or inside GeoMoose
proper?
Generally speaking...
If you are using WMS then load times should be similar.
If you are using WFS it might be faster or slower on initial load depending
on the amount of vector data transfered.  I think GeoMoose will pass a
bounding box to the WFS server so if you zoom in first it might help.  It
should be faster than GeoMoose 2 on interactions after initial data load.
GeoMoose 3 also supports using a WMS layer for display but a WFS later for
query.  That might help the initial load times.
On Fri, Jan 31, 2020, 15:27 Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> Does anyone have any advice on how to improve data rendering speeds for
> GeoMoose 3?
> I'm having some issues loading vector data quickly, although our imagery
> does also load a
> bit slower than in our GeoMoose 2 website. I'm on Windows but it doesn't
> appear to be
> inherently a Windows vs Linux issue. I can load our surveys dataset with
> GeoMoose 2
> in around 2 seconds, but when I switch to GeoMoose 3, the same dataset on
> the same server
> takes around 10 seconds to load.
> I've noticed that the services run very quickly. I can search or select
> data about as quickly
> as on GeoMoose 2, but when it comes to then zooming to results and
> rendering the data
> there's a significant lag, even when comparing GeoMoose 2 and 3 when on
> the same Windows
> server.
> Thanks for any suggestions,
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County Surveyor Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200131/976de411/attachment.html>
More information about the Geomoose-users mailing list
