[Geomoose-users] GeoMoose 3 - Speed
Christopher Hughes chughes at co.lincoln.or.us
Fri Jan 31 16:56:26 PST 2020
I'm using WMS for display and WFS for queries. The surveys dataset I
mentioned is connecting to a postgis server,
whereas the rest of my data are in shapefiles on the same server. Looking
at shp2img it looks like it's in the drawing
of the layer rather than in the web service.
Shp2img results:
-msDrawMap(): Layer 0 (Surveys), 0.043s             -    using mapfile from
geomoose 2
-msDrawMap(): Layer 0 (Surveys), 7.219s             -    using mapfile from
geomoose 3
Although that kind of points to my mapfile configuration. I'll continue
debugging.
Chris
On Fri, Jan 31, 2020 at 3:36 PM James Klassen <klassen.js at gmail.com> wrote:
> How are you loading the data in GeoMoose 3?  In GeoMoose 2 I'm guessing it
> was via WMS.
> Where are you seeing the bottleneck?  The web service or inside GeoMoose
> proper?
> Generally speaking...
> If you are using WMS then load times should be similar.
> If you are using WFS it might be faster or slower on initial load
> depending on the amount of vector data transfered.  I think GeoMoose will
> pass a bounding box to the WFS server so if you zoom in first it might
> help.  It should be faster than GeoMoose 2 on interactions after initial
> data load.
> GeoMoose 3 also supports using a WMS layer for display but a WFS later for
> query.  That might help the initial load times.
> On Fri, Jan 31, 2020, 15:27 Christopher Hughes <chughes at co.lincoln.or.us>
> wrote:
>> Does anyone have any advice on how to improve data rendering speeds for
>> GeoMoose 3?
>> I'm having some issues loading vector data quickly, although our imagery
>> does also load a
>> bit slower than in our GeoMoose 2 website. I'm on Windows but it doesn't
>> appear to be
>> inherently a Windows vs Linux issue. I can load our surveys dataset with
>> GeoMoose 2
>> in around 2 seconds, but when I switch to GeoMoose 3, the same dataset on
>> the same server
>> takes around 10 seconds to load.
>> I've noticed that the services run very quickly. I can search or select
>> data about as quickly
>> as on GeoMoose 2, but when it comes to then zooming to results and
>> rendering the data
>> there's a significant lag, even when comparing GeoMoose 2 and 3 when on
>> the same Windows
>> server.
>> Thanks for any suggestions,
>> Chris
>> Chris Hughes
>> GIS Analyst
>> Lincoln County Surveyor Department
>> 880 NE 7th St. l Newport, OR 97365
>> Tel: (541) 574 1283
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200131/66b966c3/attachment.html>
More information about the Geomoose-users mailing list
