[Geomoose-users] Geomoose 3, URL call to start a service with parameters
Eli Adam eadam at co.lincoln.or.us
Tue Jun 9 07:41:26 PDT 2020
Hi Michael,
On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
<mike.reynolds at state.mn.us> wrote:
> Is there a way to call a service or action by using a url parameter?  If not, in the app.js could I inspect the URL parameters and if I see a particular parameter name (for example "service"), initiate a service after the app loads?
You can run services at startup,
https://geomoose.github.io/gm3/howto/start-a-service.html
https://github.com/geomoose/gm3/issues/455
Best regards, Eli
> We've got user cases where users have Latitutde Longitude (WGS84) for locations which they would like to pass to a Geomoose URL as parameters to go to that location directly.  Users have noticed the coordinate values inherent in a Geomoose url but converting from WGS84 to web mercator is an extra step.
> Any tips appreciated.
> Michael Reynolds
> Application Support | Application Portfolio Management (APM)
> Minnesota IT Services | Partnering with MnDOT
> 359 John Ireland Blvd.
> St. Paul, MN  55155
> O: 651-366-4918
> Information Technology for Minnesota Government | mn.gov/mnit
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
