[Geomoose-users] GM3 - Error building on current clone
James Klassen klassen.js at gmail.com
Mon Jun 29 13:14:47 PDT 2020
And the Travis-CI integration is still listed as installed/enabled, but I
do see anything about that tests being run in the PRs.  It looks to me like
GitHub is broken w.r.t. Travis ATM.
On Mon, Jun 29, 2020, 15:11 James Klassen <klassen.js at gmail.com> wrote:
> I did look at cherry-picking the one commit from #558 but it appears to do
> more than is on the label, so I was worried that would break things more.
> On Mon, Jun 29, 2020, 15:09 James Klassen <klassen.js at gmail.com> wrote:
>> I can merge the two PRs but I haven't had time to properly look them over
>> yet.  But at the same time, if master is broken anyway, what can it hurt?
>> On Mon, Jun 29, 2020, 15:01 Christopher Hughes <chughes at co.lincoln.or.us>
>> wrote:
>>> Awesome thanks! Glad to hear it's a known issue with a fix in the works.
>>> Brent, I'll try your suggestion in the meantime.
>>> Chris
>>> On Mon, Jun 29, 2020 at 11:53 AM Brent Fraser <bfraser at geoanalytic.com>
>>> wrote:
>>>> Hi Chris,
>>>>     I think the fault is mine with a poorly tested code change.  Dan
>>>> has a
>>>> pull request pending that will fix the issues, but in the mean time you
>>>> can
>>>> simple change lines 501 and 523 to fix the two errors:
>>>>  501: delete the comment:  " // for lines..."
>>>>  523: change the
>>>>      != 200
>>>>  to
>>>>     !== 200
>>>>  Best Regards,
>>>>  Brent Fraser
>>>>  -------- Original Message --------
>>>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>>>> > Sent: June 29, 2020 12:43 PM
>>>> > To: "GeoMoose Users" <geomoose-users at lists.osgeo.org>
>>>> > Subject: [Geomoose-users] GM3 - Error building on current clone
>>>> > Hello,
>>>> > I'm having a new issue rebuilding the geomoose javascript on windows
>>>> per
>>>> > https://geomoose.github.io/gm3/install_on_windows.html
>>>> > I'm building on a current clone of geomoose 3, so the
>>>> package-lock.json
>>>> > file should be up to date with the repo. After cloning
>>>> > and running 'npm install'; running 'npm run build' fails. I've tried
>>>> > deleting the node_modules directory and re-running npm install
>>>> > without success. I haven't made any changes to my clone of the repo.
>>>> > I've included some of the relevant errors below:
>>>> > [image: image.png]
>>>> > Any tips would be appreciated!
>>>> > Chris
>>>> > Chris Hughes
>>>> > GIS Analyst
>>>> > Lincoln County Surveyor Department
>>>> > 880 NE 7th St. l Newport, OR 97365
>>>> > Tel: (541) 574 1283
>>>> > _______________________________________________ Geomoose-users
>>>> mailing
>>>> list Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> Chris Hughes
>>> GIS Analyst
>>> Tel: (541) 574 1283
>>> Geomoose-users mailing list
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200629/5a22958e/attachment.html>
More information about the Geomoose-users mailing list
