[Geomoose-users] GM3 - Error building on current clone
James Klassen klassen.js at gmail.com
Mon Jun 29 13:30:53 PDT 2020
The more I think about this, I'm going to make a PR that just fixes the
build.
On Mon, Jun 29, 2020, 15:14 James Klassen <klassen.js at gmail.com> wrote:
> And the Travis-CI integration is still listed as installed/enabled, but I
> do see anything about that tests being run in the PRs.  It looks to me like
> GitHub is broken w.r.t. Travis ATM.
> On Mon, Jun 29, 2020, 15:11 James Klassen <klassen.js at gmail.com> wrote:
>> I did look at cherry-picking the one commit from #558 but it appears to
>> do more than is on the label, so I was worried that would break things more.
>> On Mon, Jun 29, 2020, 15:09 James Klassen <klassen.js at gmail.com> wrote:
>>> I can merge the two PRs but I haven't had time to properly look them
>>> over yet.  But at the same time, if master is broken anyway, what can it
>>> hurt?
>>> On Mon, Jun 29, 2020, 15:01 Christopher Hughes <chughes at co.lincoln.or.us>
>>> wrote:
>>>> Awesome thanks! Glad to hear it's a known issue with a fix in the works.
>>>> Brent, I'll try your suggestion in the meantime.
>>>> Chris
>>>> On Mon, Jun 29, 2020 at 11:53 AM Brent Fraser <bfraser at geoanalytic.com>
>>>> wrote:
>>>>> Hi Chris,
>>>>>     I think the fault is mine with a poorly tested code change.  Dan
>>>>> has a
>>>>> pull request pending that will fix the issues, but in the mean time
>>>>> you can
>>>>> simple change lines 501 and 523 to fix the two errors:
>>>>>  501: delete the comment:  " // for lines..."
>>>>>  523: change the
>>>>>      != 200
>>>>>  to
>>>>>     !== 200
>>>>>  Best Regards,
>>>>>  Brent Fraser
>>>>>  -------- Original Message --------
>>>>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>>>>> > Sent: June 29, 2020 12:43 PM
>>>>> > To: "GeoMoose Users" <geomoose-users at lists.osgeo.org>
>>>>> > Subject: [Geomoose-users] GM3 - Error building on current clone
>>>>> > Hello,
>>>>> > I'm having a new issue rebuilding the geomoose javascript on windows
>>>>> per
>>>>> > https://geomoose.github.io/gm3/install_on_windows.html
>>>>> > I'm building on a current clone of geomoose 3, so the
>>>>> package-lock.json
>>>>> > file should be up to date with the repo. After cloning
>>>>> > and running 'npm install'; running 'npm run build' fails. I've tried
>>>>> > deleting the node_modules directory and re-running npm install
>>>>> > without success. I haven't made any changes to my clone of the repo.
>>>>> > I've included some of the relevant errors below:
>>>>> > [image: image.png]
>>>>> > Any tips would be appreciated!
>>>>> > Chris
>>>>> > Chris Hughes
>>>>> > GIS Analyst
>>>>> > Lincoln County Surveyor Department
>>>>> > 880 NE 7th St. l Newport, OR 97365
>>>>> > Tel: (541) 574 1283
>>>>> > _______________________________________________ Geomoose-users
>>>>> mailing
>>>>> list Geomoose-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Chris Hughes
>>>> GIS Analyst
>>>> Tel: (541) 574 1283
>>>> Geomoose-users mailing list
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200629/9dd227ed/attachment.html>
More information about the Geomoose-users mailing list
