[Geomoose-users] how to set SRS in Geomoose 3
flavio rigolon flavio.rigolon at gmail.com
Wed Nov 4 01:00:23 PST 2020
Hy all,
 I saw that in previous Gemoose 2 version there was a configuration
parameter in mapbook.xml to change map projection [1] like:
<param name="projection">EPSG:3857</param>
 I'll try to insert my custom parameter between a new created
<configuration> tag:
<param name="projection">EPSG:3003</param> (projection referred to west Italy)
and in app.js file I added:
    app.addProjection({
        ref: 'EPSG:3003',
        def: '+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000
+y_0=0 +ellps=intl +units=m +no_defs'
and then:
    app.registerAction('fullextent', ZoomToAction, {
        // extent: [-10742765,5398288,-9920914,6310641]
        extent: [1685000,5038000,1692400,5049400]
but it seems Geomoose always takes the coordinate in the default
reference system: at startup the map in centered on the coordinates
I've set in app.js fullextent but they are interpreted in different
EPSG than 3003 I'd like to be.
Is new Geomoose 3 mapbook.xml version working like the previous one or
have I to edit other files/parameter?
Sorry for my poor english and thanks for any suggestions
Sincerely
flavio
[1] https://docs.geomoose.org/2.9/workshops/umgeocon2016/ex6.html
/"\  ASCII Ribbon Campaign
\ /  Respect for low technology.
 X  Keep e-mail messages readable by any computer system.
/ \  Keep it ASCII.
More information about the Geomoose-users mailing list
