[Geomoose-users] Vertical position of layers when printing
TC Haddad tchaddad at gmail.com
Thu Feb 3 13:56:28 PST 2022
Yep apologies, should have mentioned that all xyz layers are at the bottom
of the Mapbook.
Seems so strange. I'll try to fit in a test with 3.8 if I can.
Tanya
On Thu, Feb 3, 2022 at 1:13 PM Brent Fraser <bfraser at geoanalytic.com> wrote:
> Hi Tanya,
> The demo (3.8.1 beta) seems to print OK.  Did you make sure the basemap
> layers are listed at the bottom of your mapbook?
> Brent
> *From*: "TC Haddad" <tchaddad at gmail.com>
> *Sent*: 2/3/22 1:27 PM
> *To*: "geomoose-users at lists.osgeo.org" <Geomoose-users at lists.osgeo.org>
> *Subject*: [Geomoose-users] Vertical position of layers when printing
> Hi folks,
> I'm encountering a strange situation with base maps when attempting to
> print. It seems that the basemap layers I have (of type="xyz" in the
> Mapbook) are drawing above all other layers in the print composer, making
> it impossible to render the PDF the way that a user would expect.
> Anything I could be doing wrong on my end that I can check? This is a
> GM3.7 app.
> Tanya
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220203/a72d2d4c/attachment.html>
More information about the Geomoose-users mailing list
