[Geomoose-users] Vertical position of layers when printing
Dan Little theduckylittle at gmail.com
Thu Feb 3 16:02:19 PST 2022
Is there a scale change happening causing your overlays to be out of range?
On Thu, Feb 3, 2022 at 15:56 TC Haddad <tchaddad at gmail.com> wrote:
> Yep apologies, should have mentioned that all xyz layers are at the bottom
> of the Mapbook.
> Seems so strange. I'll try to fit in a test with 3.8 if I can.
> Tanya
> On Thu, Feb 3, 2022 at 1:13 PM Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Hi Tanya,
>> The demo (3.8.1 beta) seems to print OK.  Did you make sure the basemap
>> layers are listed at the bottom of your mapbook?
>> Brent
>> *From*: "TC Haddad" <tchaddad at gmail.com>
>> *Sent*: 2/3/22 1:27 PM
>> *To*: "geomoose-users at lists.osgeo.org" <Geomoose-users at lists.osgeo.org>
>> *Subject*: [Geomoose-users] Vertical position of layers when printing
>> Hi folks,
>> I'm encountering a strange situation with base maps when attempting to
>> print. It seems that the basemap layers I have (of type="xyz" in the
>> Mapbook) are drawing above all other layers in the print composer, making
>> it impossible to render the PDF the way that a user would expect.
>> Anything I could be doing wrong on my end that I can check? This is a
>> GM3.7 app.
>> Tanya
> Geomoose-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220203/c4265a63/attachment.html>
More information about the Geomoose-users mailing list
