[GeoNode-devel] automatic authentication/login from geonode to geoserver does not work
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jul 16 06:04:02 PDT 2015
I did not test it in a custom environment, the solution should be to set
the /var/lib/tomcat7/webapps/geoserver/data/security/auth/geonodeAuthProvider/config.xml
to localhost or to where geonode is responding.
I'll try asap
2015-07-16 13:11 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Forwarding to the osgeo mailing list. Remember to consider the opengeo one
> as dismissed
> ---------- Forwarded message ----------
> From: Paolo Pasquali <paolo.pasquali at gmail.com>
> Date: 2015-07-16 12:47 GMT+02:00
> Subject: Re: automatic authentication/login from geonode to geoserver does
> not work
> To: geonode-dev at opengeo.org
> Cc: chrisy.wolf at gmail.com
> Hi Devs,
> I'm facing this same problem but with the latest GeoNode 2.4 beta and
> GeoServer 2.7.
> I made a custom installation in a virtualenv with both GeoNode and
> GeoServer responding on port 80.
> So I'm getting this error:
> Error connecting to the GeoNode server for authentication purposes
> GeoNode communication failed, status report is: 404, Not Found,
> http://localhost/layers/acls
> I played with the settings but without success.
> Thanks in advanced for your help.
> Bye
> Paolo
> On Wednesday, January 7, 2015 at 11:14:34 AM UTC+1, chris... at gmail.com
> wrote:
>> Hello,
>> maybe somebody can help me.
>> i have following problem:
>> Geoserver application can not find geonode application on same server to
>> authentificate and automatic login to geoserver with same credentials. I
>> must login on geoserver app again. Also layer on geonode will not display
>> because automatic login to geoserver app does not work.
>> geoserver.log say:
>> 2015-01-07 10:32:06,039 WARN [geonode.security] - Error connecting to the
>> org.springframework.security.authentication.AuthenticationServiceException:
>> Communication with GeoNode failed
>>         at
>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>>         at
>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>>         at
>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>>         at
>> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>>         at
>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>         at
>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>>         at
>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>>         at
>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>>         at
>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>         at
>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>>         at
>>         at
>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>>         at
>>         at
>>         at
>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>         at
>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>         at
>>         at
>>         at
>>         at
>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>         at
>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>>         at
>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>         at
>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>         at
>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>         at
>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>         at
>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>>         at
>>         at
>>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>         at
>>         at
>>         at
>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>>         at
>>         at
>>         at
>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>         at
>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>         at
>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>         at
>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>         at
>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>         at
>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>         at
>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>         at
>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>         at
>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
>>         at
>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>         at
>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>         at
>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>         at
>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>         at java.lang.Thread.run(Thread.java:745)
>> Caused by: java.io.IOException: GeoNode communication failed, status
>> report is: 404, Not Found, http://localhost:8080/layers/acls
>>         at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:72)
>>         at
>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>>         at
>> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>>         at
>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>>         ... 47 more
>> i have checked
>> /opt/geonode/geoserver/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>> and set baseUrl to http://localhost and also http://localhost:8080 but
>> both does not work.
>> Apache listen on Port 80
>> tcp        0      0 0.0.0.0:80              0.0.0.0:*
>> LISTEN      0          5099632     15956/apache2
>> Apache geonode.conf:
>> WSGIDaemonProcess geonode user=www-data threads=15 processes=2
>> <VirtualHost *:80>
>>     Servername localhost
>>     ServerAdmin webmaster at localhost
>>     ErrorLog /var/log/apache2/error.log
>>     LogLevel warn
>>     CustomLog /var/log/apache2/access.log combined
>>     WSGIProcessGroup geonode
>>     WSGIPassAuthorization On
>>     WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>>     <Directory "/var/www/geonode/">
>>        Order allow,deny
>>         Options Indexes FollowSymLinks
>>         Allow from all
>>         IndexOptions FancyIndexing
>>     </Directory>
>>     Alias /static/ /var/www/geonode/static/
>>     Alias /uploaded/ /var/www/geonode/uploaded/
>>     Alias /robots.txt /var/www/geonode/robots.txt
>>     <Directory "/var/www/geonode/uploaded/documents/">
>>        Order allow,deny
>>        Deny from all
>>     </Directory>
>>     <Proxy *>
>>       Order allow,deny
>>       Allow from all
>>     </Proxy>
>>     ProxyPreserveHost On
>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>> </VirtualHost>
>> My environment:
>> Ubuntu 14.04.1 LTS
>> Geoserver 2.5.1
>> Geonode 2.4dev
>> Do you need more informations?
>> Thanks for help
>> Best regards
>> Christian
>  To unsubscribe from this group and stop receiving emails from it, send an
> email to geonode-dev+unsubscribe at opengeo.org.
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150716/764fd4d6/attachment.html>
More information about the geonode-devel mailing list
