[GeoNode-devel] Broken geoserver-geonode-build
Simone Giannecchini simone.giannecchini at geo-solutions.it
Fri Jul 31 10:13:47 PDT 2015
Dear All,
JDBC Config is not used by default in GS at this stage, it is a
community extension.
We used in some set ups and I am pretty sure Boundless does use it as
well but the point is that it is not in widespread use yet.
Isn't it a bit risky to move it to default use in GeoNode, if that's
what's been done here?
Aside, the build is failing because community extensions are not
deployed by the GeoServer nightly build (we only deploy releases).
I believe that if this is the direction we want to take (mind you, I
am not against it, I am just questioning a bit the lack of discussion
:) ) we should first proposed to make this a first class extension in
GeoServer land
so we have 100% guarantee that this extension will be maintained over time.
Looking forward to reading your feedback.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Jul 31, 2015 at 5:44 PM, Daniel Berry <dberry at boundlessgeo.com> wrote:
> Sure
> On Jul 31, 2015 10:37 AM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
>> Hi All,
>> Looks like the jdbc-config addition has broken the builds in jenkins.
>> http://build.geonode.org/job/geoserver-geonode-dev/lastBuild/console
>> Daniel, Can you guys take a look at see whats up?
>> Jeff
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
