[GeoNode-devel] Time to do a Beta and a Release
Daniel Berry
dberry at boundlessgeo.com
Fri Sep 25 07:43:34 PDT 2015
maybe gsconfig 7.0.0 and gsimporter 1.0.0
On Fri, Sep 25, 2015 at 9:39 AM, Tyler Garner <garnertb at prominentedge.com>
wrote:
> We should figure this out too before releasing:
> https://github.com/boundlessgeo/gsconfig/issues/91.
> I think we should switch to semver for both of the packages.
> On Fri, Sep 25, 2015 at 10:37 AM, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
>> Ariel, can you add Daniel, Alessio and Tyler as owners/maintainers on
>> pypi?
>> On Fri, Sep 25, 2015 at 7:18 AM, Daniel Berry <dberry at boundlessgeo.com>
>> wrote:
>>> Yep, Ariel will need to do that. It might be wise to add a few other
>>> people as owners or maintainers to both gsconfig and gsimporter.
>>> On Fri, Sep 25, 2015 at 9:00 AM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>>> I believe so. Daniel, if you can make the releases to Pypi, please go
>>>> for it. Otherwise we may need help from Ariel.
>>>> On Fri, Sep 25, 2015 at 6:59 AM, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> Yes IMHO
>>>>> -A.
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/NWWaa2 for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via Poggio alle Viti 1187
>>>>> 55054 Massarosa (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>> The information in this message and/or attachments, is intended solely
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>>> strictly forbidden except previous formal approval of the named
>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>> information in this message that has been received in error. The sender
>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>> made after they were sent or for other risks which arise as a result of
>>>>> e-mail transmission, viruses, etc.
>>>>> On Fri, Sep 25, 2015 at 3:57 PM, Daniel Berry <dberry at boundlessgeo.com
>>>>> > wrote:
>>>>>> In regards to the gsimporter and gsconfig are we at a point where we
>>>>>> can update pypi.
>>>>>> I loaded both on testpypi
>>>>>> gsimporter - https://testpypi.python.org/pypi/gsimporter/0.2
>>>>>> gsconfig - https://testpypi.python.org/pypi/gsconfig/0.6.14
>>>>>> Dan
>>>>>> On Fri, Sep 25, 2015 at 4:04 AM, Paolo Corti <pcorti at gmail.com>
>>>>>> wrote:
>>>>>>> Hi Alessio
>>>>>>> > On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>> >> I agree to start releasing a new beta (beta 27) and maybe start
>>>>>>> >> thinking about releasing a RC1 (time is short to the sprint).
>>>>>>> >> By the way: I see several issues still open regarding GeoServer
>>>>>>> >> integration [1], maybe it would be great to do a triage to check
>>>>>>> what
>>>>>>> >> it was fixed and what it was not.
>>>>>>> >> Personally I see #2177 as a blocker to move our production to GS
>>>>>>> 2.7.
>>>>>>> > I did not have the chance to look deeply in to this yet, but at a
>>>>>>> first
>>>>>>> > glance I'm not fully sure this depends on GS. It seems to be more
>>>>>>> an issue
>>>>>>> > on GeoNode side. Do you have any more details? In any case I'll
>>>>>>> try to find
>>>>>>> > some time to inspect this issue as soon as possible. (Also, make a
>>>>>>> try using
>>>>>>> > the very latest versions of gsconfig and gsimporter, the
>>>>>>> communication
>>>>>>> > between the client and GeoServer has several fixes and
>>>>>>> improvements which
>>>>>>> > maybe already fixed this issue too)
>>>>>>> we can look into this at the sprint, and yes you are correct, it is
>>>>>>> just Django, sorry for the confusion.
>>>>>>> >> Is the SQL security backend correctly working with GS 2.7 [2]?
>>>>>>> > Never tested. Can you please send me few lines and details in
>>>>>>> order to test
>>>>>>> > and troubleshoot this?
>>>>>>> http://docs.geonode.org/en/dev/deploy/production.html#installing-the-stored-procedure
>>>>>>> hope it helps
>>>>>>> cheers
>>>>>>> p
>>>>>>> Paolo Corti
>>>>>>> Geospatial software developer
>>>>>>> web: http://www.paolocorti.net
>>>>>>> twitter: @capooti
>>>>>>> skype: capooti
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>> *Daniel Berry*
>>>>>> Professional Services Engineer | Boundless
>>>>>> 512-468-3946 (cell)
>>>>>> @boundlessgeo
>>> *Daniel Berry*
>>> 512-468-3946 (cell)
>>> @boundlessgeo
> *Tyler Garner*
> Co-Founder | Prominent Edge
> Office: 703-743-5434
> Mobile: 434-841-3803
> prominentedge.com
*Daniel Berry*
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150925/d5913690/attachment-0001.html>
More information about the geonode-devel
