[GeoNode-devel] Costumize metadata geonode editor
Eduardo Pascoal pascoal.egeo at gmail.com
Tue Sep 29 08:48:26 PDT 2015
Ariel Nunez,
thanks for your prompt answer but probably i didn't make myself clear..
That is an interesting point to do.  Fork geonode and create a INSPIRE
branch with the new metadata editor which for sure would be great for
geonode but my problem is beyond that.
My question it has to do with the begining of all this. How to costumize
geonode editor? How dificult is to do that? Geonode predict this kind of
costumization? What modifications should i consider?
2015-09-29 16:14 GMT+01:00 Ariel Nunez <ingenieroariel at gmail.com>:
> When modifying the metadata schema, my approach has been to just fork
> GeoNode and keep the changes restricted to ONLY that change.
> The workflow would be:
> 1. Make sure you have a master branch in your repo that is an exact copy
> of GeoNode master.
> 2. Create a branch with your project name or called 'inspire' for example.
> Commit the metadata changes there.
> 3. If you installed via packages, replace the existing geonode with your
> version (careful with local_settings.py), clone it via git and then do pip
> install -e on the folder
> 4. When 2.4 is final, update your version of master with the latest from
> GeoNode master (exact copy).
> 5. Merge your master into your inspire branch.
> 6. Pull the changes from your server into the folder where you did the git
> clone and reload apache.
> It sounds a bit convoluted but has worked for me, metadata changes are not
> easy to do as external apps, contrib or extensions ...
> -a
> On Tue, Sep 29, 2015 at 10:02 AM, Eduardo Pascoal <pascoal.egeo at gmail.com>
> wrote:
>> Dear all,
>> *Scenario:*
>> i have my own metadata profile based on ISO19139 and INSPIRE
>> implementation rules. I would like to understand how can i modify the
>> geonode metadata editor with extra fields according to my own metadata
>> profile.
>> *Question*
>> What is the best approach to do a metadata editor?  Should i edit base
>> app on contrib folder and update model.py? or create my own app that should
>> override base? What dependencies must i consider to do this?
>> Do you know any documentation about this subject that you suggest?
>> Any help would be great
>> Best regards,
>> Eduardo Pascoal
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Eduardo Pascoal
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150929/f443e563/attachment.html>
More information about the geonode-devel mailing list
