[GeoNode-devel] Fixing Geonode master syncdb
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 8 00:12:07 PDT 2016
ok I'll take care of this today
2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> +1 on adding dan, alessio and sarah to be able to push on pypi
> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
>> We may want to open pypi up for others to push new updated versions,
>> especially with the 2.5 and 2.6 releases coming up.
>> Thoughts?
>> Dan
>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Dear all,
>>> accordingly to this issue
>>> https://github.com/GeoNode/geonode/issues/2488
>>> the DJango migrations arebroken due to the old versions of GeoNode
>>> components
>>> geonode_dialogos-0.4
>>> geonode_agon_ratings-0.3.4
>>> geonode_user_accounts-1.0.10
>>> geonode_avatar-2.1.4
>>> geonode_announcements-1.0.7
>>> geonode_user_messages-0.1.2
>>> I see the associated Pull Requests from Emanuele Tajariol have been
>>> merged, but this won't be sufficient in order to let GeoNode working again.
>>> We need to update the components versions, push the new packages into
>>> pypi and update the GeoNoser Seup.py file with the new versions.
>>> How can we do this? Is there an administrator who can help us issue the
>>> new releases?
>>> Best Regards,
>>> Alessio Fabiani.
>>> GeoServer Professional Services from the experts!
>>> Visit http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> *Daniel Berry*
>> Senior Software Engineer | Boundless
>> 512-468-3946 (cell)
>> @boundlessgeo
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/c54cee4d/attachment-0001.html>
More information about the geonode-devel mailing list
