[GeoNode-devel] Upgrade to GeoServer 2.9
Erik Merkle emerkle at boundlessgeo.com
Fri Jul 8 21:57:13 PDT 2016
All,
The GeoServer plugin for GeoGig has been merged into both the 2.9.x branch
of GeoServer as well as the master branch (GeoServer 2.10). The GeoGig jars
are on the Boundless repos as well. Hopefully this removes any GeoGig
related roadblocks for the upgrade.
​Regards,
Erik
On Fri, Jul 8, 2016 at 9:14 AM, Erik Merkle <emerkle at boundlessgeo.com>
wrote:
> Alessio,
> The latest stable GeoGig jars are already being pushed to the Boundless
> repo here:
> https://repo.boundlessgeo.com/snapshot
> The 1.0-SNAPSHOT version is stable and what the plugin is using (the
> plugin for GS 2.8 uses 1.0-SNAPSHOT and 2.9 and master will use the same
> GeoGig 1.0-SNAPSHOT version as soon as I get the PRs merged). You can build
> against the GeoGig jars by adding something like this to your POM:
>     <dependency>
>       <groupId>org.locationtech.geogig</groupId>
>       <artifactId>geogig-web-api</artifactId>
>       <version>1.0-SNAPSHOT</version>
>     </dependency>
> There is also a Release Candidate version in the Boundless Artifactory
> here:
> https://repo.boundlessgeo.com/release
> But the latest release is version 1.0-RC2, dated early April.
> As for the plugin, I've got it all working for GS 2.9 and GS 2.10
> (master), just need to finish up a few functional tests and the PRs will be
> created.
> ​Regards,
>> Erik
> On Fri, Jul 8, 2016 at 2:41 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Very good,
>> thanks for your help.
>> Is there a way to push the geogig jars on the boundless maven repo when
>> ready too?
>> Thenaks again and kind regards,
>> -A.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jul 8, 2016 at 3:46 AM, Erik Merkle <emerkle at boundlessgeo.com>
>> wrote:
>>> I think I have the plugin for GeoGig ported over to GeoServer 2.9 and
>>> master (2.10). I'm finishing up some testing on them and as soon as I'm
>>> finished, I'll submit the PRs. Getting the plugin into the master branch on
>>> GeoServer should keep the plugin from causing issues with upgrading to
>>> GeoNode to use GeoServer 2.10, when that time comes.
>>> Erik Merkle
>>> On Thu, Jul 7, 2016 at 11:40 AM, Erik Merkle <emerkle at boundlessgeo.com>
>>> wrote:
>>>> All,
>>>> I've started to look at getting the plugin for GeoGig ported over from
>>>> GeoServer 2.8.x to 2.9.x. Most of the issues are related to the Wicket
>>>> version changes and seem to be fairly easy to address. I hope to have it
>>>> ported over soon and I'll update the mailing list with my progress.
>>>> ​Regards,​
>>>> Erik Merkle
>>>> On Thu, Jul 7, 2016 at 9:44 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>> wrote:
>>>>> +1 on moving to 2.9 with just a PR and ensuring the build works
>>>>> properly on build.geonode.org
>>>>> +100 to boundless and geosolutions coordinating on these issues :)
>>>>> +1000 on moving to a default geoserver build that doesnt require this
>>>>> plugin
>>>>> On Thu, Jul 7, 2016 at 7:40 AM, Alessio Fabiani <
>>>>>> Hi Daniel,
>>>>>> we can discuss when you are available during our both working hours I
>>>>>> guess. My timezone is Rome - Italy one.
>>>>>> Thanks for your support.
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Thu, Jul 7, 2016 at 4:09 PM, Daniel Berry <dberry at boundlessgeo.com
>>>>>> > wrote:
>>>>>>> Alessio,
>>>>>>> I would think an issue and PR would be sufficient. We should add
>>>>>>> what new features or changes are included though.
>>>>>>> regarding the following
>>>>>>> "*We need boundless to fix geogig 2.9.x version which is currently
>>>>>>> broken. We need geogig JARs to be pushed on a public maven repository,
>>>>>>> otherwise GeoServer won't compile. Is there someone from boundless which
>>>>>>> can eventually help us with this task?"*
>>>>>>> We sure can, Erik Merkle is currently researching the level of
>>>>>>> effort for GeoGig 2.9.x extension. This would be great if we
>>>>>>> could include this in the GeoNode 2.5 release. Would you like to schedule a
>>>>>>> time to discuss?
>>>>>>> Respectfully,
>>>>>>> Daniel Berry
>>>>>>> On Thu, Jul 7, 2016 at 8:13 AM, Alessio Fabiani <
>>>>>>>> Dear all,
>>>>>>>> I managed to succesfully update the geoserver-genode-ext to the 2.9
>>>>>>>> version, but there are still two things to discuss:
>>>>>>>> 1. Everyone is ok with this GeoServer version? Should we go through
>>>>>>>> a GNIP or an issue and PR are sufficient?
>>>>>>>> 2. We need boulndless to fix geogig 2.9.x version which is
>>>>>>>> currently broken. We need geogid JARs to be pushed on a public maven
>>>>>>>> repository, otherwise GeoServer won't compile. Is there someone from
>>>>>>>> boundless which can eventually help us with this task?
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> _______________________________________________
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> *Daniel Berry*
>>>>>>> Senior Software Engineer | Boundless
>>>>>>> 512-468-3946 (cell)
>>>>>>> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/6888ed31/attachment-0001.html>
More information about the geonode-devel mailing list
