[GeoNode-devel] Geoserver connection issue
Francesco Bartoli xbartolone at gmail.com
Mon Apr 3 22:46:03 PDT 2017
Dear Micheal,
did you run the command “sudo paver setup” ? If not what geoserver did you install?
Francesco
Il giorno 04/apr/2017, alle ore 01:39, Michael Peterman <mpetermangis at gmail.com> ha scritto:
> Hi,
> I am installing a custom copy of Geonode 2.4, as per these instructions:
> http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/install_geonode_application.html
> I pulled from this git branch: https://github.com/GeoNode/geonode.git --branch 2.4.x
> and installed on a fresh copy of Ubuntu 14.04 64-bit.
> Everything appears to work fine, but after finishing the installation, the connection between Geoserver and Postgres seems to be broken. Any data that I try to upload to Geonode gives this error: "An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table"
> The logs in Geoserver show a series of exceptions like this:
> 2017-04-01 23:55:40,930 WARN [geonode.security] - Error connecting to the GeoNode server for authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException: Communication with GeoNode failed (GeoNodeSessionAuthToken)
> Caused by: java.net.SocketTimeoutException: Read timed out
> I am using the same credentials for the Postgres account (geonode / geonode) that are in the instructions.  Geoserver, Postgres, and Geonode are all hosted on the same machine.
> Thanks in advance to everyone, I really appreciate all the effort that has gone into this project.
> Mike
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170404/a348385b/attachment.html>
More information about the geonode-devel mailing list
