[GeoNode-devel] Geoserver connection issue
Michael Peterman mpetermangis at gmail.com
Wed Apr 5 18:14:19 PDT 2017
The datastore was configured to use the geonode db on a Postgres backend,
as per the instructions. The only thing I'm not sure about--is the database
supposed to be "geonode" or "geonode_*data*"? Here's a screenshot of the
settings:
[image: Inline image 1]
In any case I will try installing this again on a fresh VM.
Thanks,
Michael
On Wed, Apr 5, 2017 at 6:40 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> In this way you are using the dev environment which by default is relying
> on a sqlite database. I'm assuming you changed the default settings and
> have configured the geonode-data database. In this case what is the
> configuration of the datastore for that in geoserver?
> Can you please check it using the UI?
> Thanks
> Francesco
> 5 apr 2017, 02:31 +0200, Michael Peterman <mpetermangis at gmail.com>, ha
> scritto:
> Hi Francesco,
> Yes I ran that command. Output is:
> ---> pavement.setup
> ---> pavement.setup_geoserver
> rmtree geoserver/data
> GeoNode development environment successfully set up.If you have not set up
> an administrative account, please do so now. Use "paver start" to start up
> the server.
> Geoserver is version 2.7.4 on Java  1.7.0_121 (OpenJDK 64-Bit Server VM)
> Any other ideas for what I can try?
> Thanks again,
> Michael
> On Tue, Apr 4, 2017 at 1:46 AM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Dear Micheal,
>> did you run the command “sudo paver setup” ? If not what geoserver did
>> you install?
>> Francesco
>> Il giorno 04/apr/2017, alle ore 01:39, Michael Peterman <
>> mpetermangis at gmail.com> ha scritto:
>> Hi,
>> I am installing a custom copy of Geonode 2.4, as per these instructions:
>> http://docs.geonode.org/en/latest/tutorials/install_and_admi
>> n/geonode_install/install_geonode_application.html
>> I pulled from this git branch: https://github.com/GeoNode/geonode.git
>> --branch 2.4.x
>> and installed on a fresh copy of Ubuntu 14.04 64-bit.
>> Everything appears to work fine, but after finishing the installation,
>> the connection between Geoserver and Postgres seems to be broken. Any data
>> that I try to upload to Geonode gives this error: "An exception occurred
>> loading data to PostGIS- java.io.IOException: Error occurred creating table"
>> The logs in Geoserver show a series of exceptions like this:
>> 2017-04-01 23:55:40,930 WARN [geonode.security] - Error connecting to the
>> GeoNode server for authentication purposes
>> org.springframework.security.authentication.AuthenticationServiceException:
>> Communication with GeoNode failed (GeoNodeSessionAuthToken)
>> Caused by: java.net.SocketTimeoutException: Read timed out
>> I am using the same credentials for the Postgres account (geonode /
>> geonode) that are in the instructions.  Geoserver, Postgres, and Geonode
>> are all hosted on the same machine.
>> Thanks in advance to everyone, I really appreciate all the effort that
>> has gone into this project.
>> Mike
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170405/c9b7f409/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170405/c9b7f409/attachment.png>
More information about the geonode-devel mailing list
