[GeoNode-devel] Geoserver connection issue
Michael Peterman mpetermangis at gmail.com
Sat Apr 8 12:56:47 PDT 2017
Thanks everyone for your help. I managed to get it running on a new Ubuntu
VM.
I can upload layers now. However, the uploaded layers don't display
correctly in the map. The background (bing maps or OpenStreetMap) displays
fine, but the vector tiles are not rendered correctly. I am uploading
zipped WGS84 shapefiles that worked on a previous installation of Geonode a
few months ago. Has anyone else seen this issue?
[image: Inline image 2]
On Thu, Apr 6, 2017 at 2:11 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> The database "geonode" is for the configuration data of django application
> while "geonode_data" is for the spatial data which will be uploaded.
> So in geoserver you have to configure the latter.
> Hope this helps
> Francesco
> 6 apr 2017, 03:14 +0200, Michael Peterman <mpetermangis at gmail.com>, ha
> scritto:
> The datastore was configured to use the geonode db on a Postgres backend,
> as per the instructions. The only thing I'm not sure about--is the database
> supposed to be "geonode" or "geonode_*data*"? Here's a screenshot of the
> settings:
> [image: Inline image 1]
> In any case I will try installing this again on a fresh VM.
> Thanks,
> Michael
> On Wed, Apr 5, 2017 at 6:40 AM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> In this way you are using the dev environment which by default is relying
>> on a sqlite database. I'm assuming you changed the default settings and
>> have configured the geonode-data database. In this case what is the
>> configuration of the datastore for that in geoserver?
>> Can you please check it using the UI?
>> Thanks
>> Francesco
>> 5 apr 2017, 02:31 +0200, Michael Peterman <mpetermangis at gmail.com>, ha
>> scritto:
>> Hi Francesco,
>> Yes I ran that command. Output is:
>> ---> pavement.setup
>> ---> pavement.setup_geoserver
>> rmtree geoserver/data
>> GeoNode development environment successfully set up.If you have not set
>> up an administrative account, please do so now. Use "paver start" to start
>> up the server.
>> Geoserver is version 2.7.4 on Java  1.7.0_121 (OpenJDK 64-Bit Server VM)
>> Any other ideas for what I can try?
>> Thanks again,
>> Michael
>> On Tue, Apr 4, 2017 at 1:46 AM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Dear Micheal,
>>> did you run the command “sudo paver setup” ? If not what geoserver did
>>> you install?
>>> Francesco
>>> Il giorno 04/apr/2017, alle ore 01:39, Michael Peterman <
>>> mpetermangis at gmail.com> ha scritto:
>>> Hi,
>>> I am installing a custom copy of Geonode 2.4, as per these instructions:
>>> http://docs.geonode.org/en/latest/tutorials/install_and_admi
>>> n/geonode_install/install_geonode_application.html
>>> I pulled from this git branch: https://github.com/GeoNode/geonode.git
>>> --branch 2.4.x
>>> and installed on a fresh copy of Ubuntu 14.04 64-bit.
>>> Everything appears to work fine, but after finishing the installation,
>>> the connection between Geoserver and Postgres seems to be broken. Any data
>>> that I try to upload to Geonode gives this error: "An exception occurred
>>> loading data to PostGIS- java.io.IOException: Error occurred creating table"
>>> The logs in Geoserver show a series of exceptions like this:
>>> 2017-04-01 23:55:40,930 WARN [geonode.security] - Error connecting to
>>> the GeoNode server for authentication purposes
>>> org.springframework.security.authentication.AuthenticationServiceException:
>>> Communication with GeoNode failed (GeoNodeSessionAuthToken)
>>> Caused by: java.net.SocketTimeoutException: Read timed out
>>> I am using the same credentials for the Postgres account (geonode /
>>> geonode) that are in the instructions.  Geoserver, Postgres, and Geonode
>>> are all hosted on the same machine.
>>> Thanks in advance to everyone, I really appreciate all the effort that
>>> has gone into this project.
>>> Mike
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170408/3f2e0873/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170408/3f2e0873/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170408/3f2e0873/attachment-0003.png>
More information about the geonode-devel mailing list
