[GeoNode-devel] Question about development
Ezequiel Gonzalez Rial gonrial at gmail.com
Thu Feb 23 05:02:31 PST 2017
I reported an issue [1] every time you click 3D View nothing is shown and
an error appears in the console.
The source of the error is that Google drop support of Google Earth by end
of 2015 and the solution is to change the config file of Geoexplorer, to
remove the option.
As this affects all the versions and branches of geonode I wanted to know
where to push the change.
[1] https://github.com/GeoNode/geonode/issues/2921
Ezequiel
2017-02-23 5:12 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi usually we discuss the bugs, here is fine, then open the tickets in
> github and accept prs. Based on the bug type we can help you address the
> correct branch.
> Thanks
> Il giorno gio 23 feb 2017 alle 06:58 Ezequiel Gonzalez Rial <
> gonrial at gmail.com> ha scritto:
>> Hi guys,
>> Sorry to ask but it's my first time submitting and I'd like to do it
>> right.
>> I found several bugs affecting almost all the versions, how is the policy
>> for pull request? Should I pull to 2.0 or should I pull to all the active
>> branches as well?
>> Best regards,
>> Ezequiel
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170223/b00bceec/attachment.html>
More information about the geonode-devel mailing list
