[GeoNode-devel] Few notes on GeoNode branch 2.7.x
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue May 9 15:53:59 PDT 2017
Thanks,
+1
Angelos
On 05/08/2017 11:31 AM, Simone Dalmasso wrote:
> Thanks Alessio.
> +1
> 2017-05-05 17:19 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
>> Dear all,
>> recently I have forked from master a branch 2.7.x of GeoNode.
>> I'm writing some lines here in order to provide you some glance on the
>> work there and what it is containing.
>> 1. First point, 2.7.x is aligned with ALL commits on master and 2.6.x
>> *except* the new notification and pubsub stuff which is still a work in
>> progress
>> 2. Secondly, 2.7.x works against GeoServer 2.10.x with a first support for
>> QGis styles. The support is not yet full compliant on GeoServer side, but
>> nevertheless you can create your style on QGis client, export is as an SLD
>> (for rasters you will need to use the SLD4Raster plugin) and import it
>> directly on GeoServer. With minor manual editing it will result in
>> something almost identical to QGis. *WARNING* there are limitations. Please
>> refer to GeoServer documentation about that.
>> 3. 2.7.x has improvements and fixes oriented to *stabilization". It is
>> constantly tested on real use case, maintained and updated in order to
>> improve performances, functionalities and reliability.
>> As soon as possible the idea would be to allow the master become 2.8.x+
>> and 2.7.x next candidate for the GeoNode release.
>> Long story short, please use it, test it and let's have a plan for pushing
>> forward further GeoNode releases.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> github <https://github.com/afabiani?tab=overview>
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <(331)%20623-3686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170510/c55104c3/attachment.html>
More information about the geonode-devel mailing list
