[GeoNode-devel] Read-only exception on layers
Francesco Bartoli xbartolone at gmail.com
Tue Oct 3 08:22:38 PDT 2017
If you changed the ip of your server than you have to make sure this command has been executed:
sudo geonode-updateip "youraddress or FQDN"
Hope this helps
Il giorno 25/set/2017, alle ore 14:53, GIDEON YEGON <gyegon2001 at gmail.com> ha scritto:
> Hi All
> Am getting this read-only exception error when i try to create or modify layers on map page.
> Also the url displayed on pop up error  contains old_ip and and am using a new server with new_ip.
> Has anyone experience this before.
> Thanks in advance.
> Kind regards
> Gideon Yegon
> Phone: +254 713 280 960
> http://www.linkedin.com/in/gyegon
> skype: g.yegon
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20171003/3e5f6d6a/attachment.html>
More information about the geonode-devel mailing list
