[GeoNode-devel] Clarifications on GeoNode branches, version numbers and deb packages
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 7 01:22:35 PDT 2017
Dear all,
after a talk with Simone Dalmasso, which clarified to me how GeoNode
project manages versioning and branchning, I'm going to summarize here the
current status on this topic on the next steps.
 - GeoNode odd version number are considered "unstable", which means they
must be tested before promoted to a stable one. Therefore currently the
2.7.x is unstable and after the testing cycle it will be promoted to 2.8.x
- GeoNode branch 2.7.x will contain versions which will be published to
Launchapd and Pypi. Currently the version we need to release on
"ppa:geonode/unstable" should be the "2.7.0.alpha.0"
- GeoNode "master" branch should instead be bumped to 2.9dev version
- After the testing cycle, once the 2.7.x will be considered stable, we
will need to bump it to 2.8.0 and release on "ppa:geonode/testing" while in
alpha and beta and "ppa:geonode/stable" when in rc and final state
Did I miss something? Any other consideration or things to add?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20170907/82d05917/attachment.html>
More information about the geonode-devel mailing list
