[GeoNode-devel] Layers on Geocode being redirected to localhost after production server migration
Lian Feng (lfeng)
lfeng at memphis.edu
Tue Aug 14 07:11:05 PDT 2018
Dear all,
Thank you so much for all the responses and I appreciate it very much.
Toni, geonode was installed from github source and followed instructions from http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html. After I dumped database geonode as sql, there isn’t anything for localhost. Here is the command I used (pg_dump -h localhost -U geonode > outfile) and output file is attached in the email. For the tables in https://hastebin.com/ipapejinex.sql<https://hastebin.com/ekodomixuc.sql>, none of them seems to be present in the geonode database. Any idea about why is different?
Alessio, I already updated geoserver proxy base url in the danjo admin gui and passwords. I will change debug to False after this issue is resolved.
Thanks again!
Lydia Lian Feng
Senior Research Software Developer | CAESER
Center for Applied Earth Science and Engineering Research
[cid:image001.jpg at 01D1B286.94FA79E0]
The University of Memphis
Wilder Tower Suite 900
3675 Alumni Drive
Memphis, TN 38152<http://www.memphis.edu/emailsignatures/emailsignaturepc.php>
901.678.<http://www.memphis.edu/emailsignatures/emailsignaturepc.php>5110 | http://strengthencommunities.com/
[cid:image002.jpg at 01D1B286.94FA79E0]<https://www.facebook.com/CAESER.UofM>
[cid:image003.jpg at 01D1B286.94FA79E0]<https://twitter.com/CAESER_UofM>
From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
Date: Tuesday, August 14, 2018 at 4:59 AM
To: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Cc: "Lian Feng (lfeng)" <lfeng at memphis.edu>, geonode-devel <geonode-devel at lists.osgeo.org>
Subject: Re: [GeoNode-devel] Layers on Geocode being redirected to localhost after production server migration
+1 Alessio, thanks for your addition!
And sorry for the many typos, it was early morning ;)
t.
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil +49/ (0) 176 6680 3198
Tel +49/ (0) 341 24 04 738
Fax +49/ (0) 341 24 04 73
Web http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
Am 14.08.2018 um 10:22 schrieb Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>:
Adding to Toni response, do not forget to change the GeoServer Proxy Base URL from the admin gui and also to change all the default passwords whenever you will deploy this on a production instance.
Also, on production, you should put "DEBUG = False" on Python settings, otherwise you are going to expose an open http-proxy to the world.
Il giorno mar 14 ago 2018 alle ore 07:48 Toni Schönbuchner <toni.schoenbuchner at csgis.de<mailto:toni.schoenbuchner at csgis.de>> ha scritto:
Dear Lydia,
in case you installed geonode 2.8 via apt-get you can just run
$ geonode-updateip http://geoportal-test.memphis.edu<http://geoportal-test.memphis.edu/>
In case you installed with form github source (with pip and paver)
Either dump database geonode as sql, search after localhost and replace
it with you url, and restore the database.
As alternative you can try these sql command (meant to be run from cli)
After using the first two pink tiles should be gone. The rest should
correct several other fields which have the old url.
best regards,
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Web http://csgis.de<http://csgis.de/>
Am 14.08.2018 um 00:18 schrieb geonode-devel-request at lists.osgeo.org<mailto:geonode-devel-request at lists.osgeo.org>:
Send geonode-devel mailing list submissions to
geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/geonode-devel
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geonode-devel-owner at lists.osgeo.org<mailto:geonode-devel-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of geonode-devel digest..."
Today's Topics:
1. Layers on Geocode being redirected to localhost after
production server migration (Lian Feng (lfeng))
Message: 1
Date: Mon, 13 Aug 2018 22:11:55 +0000
From: "Lian Feng (lfeng)" <lfeng at memphis.edu<mailto:lfeng at memphis.edu>>
To: "geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>" <geonode-devel at lists.osgeo.org<mailto:geonode-devel at lists.osgeo.org>>
Subject: [GeoNode-devel] Layers on Geocode being redirected to
Message-ID: <C79FD08F-F674-4000-965C-3B7DFB8D310D at memphis.edu<mailto:C79FD08F-F674-4000-965C-3B7DFB8D310D at memphis.edu>>
Content-Type: text/plain; charset="utf-8"
Dear all,
I installed geonode 2.8 on a 16.04 Ubuntu virtualbox and migrated localhost and localhost:8080 to http://geoportal-test.memphis.edu/ and http://geoportal-test.memphis.edu/geoserver/. I was able to upload three layers in geoserver and layer previews work well for them. However, on geonode UI, GET requests are redirected to localhost (see attached). Also, I noticed I have pink tiles for openstreetmap but not sure if they’re related. geoserver.log file is also attached.
I followed this installation guide http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html. And I have thoroughly googled pink tiles and url redirect issues but haven’t had any luck yet. I would appreciate any help very much! Thanks.
Lydia Lian Feng
3675 Alumni Drive
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment-0001.jpg>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment-0002.jpg>
Type: image/png
Desc: geonode_re-route.png
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment.png>
Type: application/octet-stream
Desc: geoserver.log
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180813/62a58ccf/attachment.obj>
Subject: Digest Footer
End of geonode-devel Digest, Vol 43, Issue 11
Professional Services from the experts! Visit <http://goo.gl/it488V>
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions
S.A.S.
Via di Montramito 3/A
- 55054 Massarosa
(LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it<http://www.geo-solutions.it/>
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180814/0e459bd2/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180814/0e459bd2/attachment-0003.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180814/0e459bd2/attachment-0004.jpg>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180814/0e459bd2/attachment-0005.jpg>
Desc: outfile
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180814/0e459bd2/attachment-0001.obj>
More information about the geonode-devel
