[GeoNode-devel] 2.8.0 - ACCOUNT_APPROVAL_REQUIRED setting appears not to have effect
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jun 7 00:55:59 PDT 2018
Fixed by
https://github.com/GeoNode/geonode/pull/3825/commits/117bbdccc38929216a4882999f586b3d51b4a0c4
2018-05-31 10:20 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Hi Dave,
> yes, it is possible that this feature has not yet completed.
> Will try to take look as soon as I can.
> 2018-05-30 18:03 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>> Hi Alessio,
>> Yes, the email backend is already configured, and it works on my site for
>> both pinax notifications and the standard account emails.
>> I was expecting to see an email template for the email from geonode to
>> the admin, stored in this folder:
>> https://github.com/GeoNode/geonode/tree/2.8.0/geonode/templa
>> tes/account/email
>> But there is no template? and the  moderator_contacted
>> <https://github.com/GeoNode/geonode/blob/d41328bfddbe3d5820338f455c5767b2067d759d/geonode/views.py#L151> function
>> seems to just get the user model to display the email address in the
>> template rather than actually sending anything.
>> I don't think this is meant to be covered by pinax, but I had a look
>> there and couldn't find anything either.
>> Is it possible this feature has not yet been implemented?
>> On 30 May 2018 at 19:12, Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it> wrote:
>>> Hi,
>>> in order to receive emails you need to configure the email backend too,
>>> which is disabled by default
>>> 2018-05-30 16:53 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
>>>> Hi all,
>>>> I'm using 2.8.0.
>>>> The ACCOUNT_APPROVAL_REQUIRED setting appears to work in that it stops
>>>> a new user's account being immediately active, but geonode does not appear
>>>> to be emailing the admins to let them know, resulting in some pretty lonely
>>>> users not being onboarded.
>>>> Looking through the code, I was expecting a notification to be sent to
>>>> the admins from here:
>>>> Am I missing something here, or does this need a fix?
>>>> Thanks
>>>> Dave
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A -
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>>>  Massarosa
>>> (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180607/392ca145/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180607/392ca145/attachment-0001.png>
More information about the geonode-devel mailing list
