[GeoNode-devel] [GeoNode-users] Release schedule proposal for GeoNode 2.8.1 and 2.10.0 versions
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu May 17 07:04:47 PDT 2018
Not on my side, just xenial has been tested extensively.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-05-17 15:58 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Looking at the 18.04 django version I see it's actually 1.11. If we
> publish for it then we can just keep the release ppa as they won't mix.
> In the past we always followed the ubuntu django versions and I we could
> keep it if there's agreement.
> Is there a specific need to keep xenial?
> 2018-05-17 15:52 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Good question.
>> Probably it is better to publish 2.10 on unstable ppa. I would keep
>> Xenial for the moment.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> 2018-05-17 15:35 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Ciao Alessio, thank you very much for your work and the proposal.
>>> So the 2.10 will be out in parallel to the 2.8.x? Wil it be published
>>> for which Ubuntu release and on which ppa?
>>> 2018-05-17 11:24 GMT+02:00 Toni Schönbuchner <
>>> toni.schoenbuchner at csgis.de>:
>>>> Thanks for clarification Alessio!
>>>> Cheers,
>>>> Toni
>>>> CSGIS
>>>> Kolonnadenstraße 1
>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>> 04109 Leipzig
>>>> Mobil +49/ (0) 176 6680 3198
>>>> Tel  +49/ (0) 341 24 04 738
>>>> Fax  +49/ (0) 341 24 04 73
>>>> Web http://csgis.de
>>>> Hinweis gemäß § 33 BDSG
>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>>> ausschließlich für den
>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>> diese E-Mail versehentlich
>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>> löschen Sie diese Nachricht
>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>> Vervielfältigung, Veränderung,
>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>> Am 17.05.2018 um 11:01 schrieb Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>> Hi Toni,
>>>> well actually is not that easy to run GeoNode tests. You need to setup
>>>> environment variables and use paver to run them.
>>>> Please take a look at Travis jobs, you can see envs and commands to run
>>>> from there
>>>> e.g. for Django 1.8.19 based GeoNode:
>>>> https://travis-ci.org/GeoNode/geonode/builds/379812453
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054  Massarosa
>>>> (LU)
>>>> Italy
>>>> 2018-05-17 9:48 GMT+02:00 Toni Schönbuchner <
>>>>> Dear Alessio,
>>>>> thanks a lot for pushing 2.8.1! Therefore I would like to ask if it´s
>>>>> known/expected that tests fail:
>>>>> https://github.com/GeoNode/geonode/issues/3806
>>>>> ( or if I´m just forgetting something when running tests. )
>>>>> Cheers,
>>>>> Toni
>>>>> CSGIS
>>>>> Kolonnadenstraße 1
>>>>> 04109 Leipzig
>>>>> Web http://csgis.de
>>>>> ist ausschließlich für den
>>>>> Am 16.05.2018 um 17:24 schrieb geonode-devel-request at lists.osgeo.org:
>>>>> On Wed, May 16, 2018 at 8:21 AM Alessio Fabiani <alessio.fabiani at geo-
>>>>> solutions.it> wrote:
>>>>> Dear dev and users lists,
>>>>> I would like to propose a time schedule for the GeoNode releases:
>>>>> - 2.10.0; based on Django 1.11.11
>>>>> - 2.8.1; based on Django 1.8.19
>>>>> Since, in terms of issues, they look stable enough to be published, I
>>>>> would like to release them in a week or so.
>>>>> Unless there are complains about that, I would call for an hardening
>>>>> week
>>>>> starting from today and then pushing out the releases on Thursday (24)
>>>>> or
>>>>> Friday (25) next week.
>>>>> In the meantime would be good to spot all potential several issues
>>>>> which
>>>>> might block the release process.
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180517/70597b0d/attachment-0001.html>
More information about the geonode-devel mailing list
