[GeoNode-devel] FOSS4G 2019 GeoNode status talk
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Apr 15 05:42:43 PDT 2019
Done
Il giorno lun 15 apr 2019 alle ore 14:40 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Yeps. Thanks both.
> Il giorno lun 15 apr 2019 alle ore 14:39 Angelos Tzotsos <
> gcpp.kalxas at gmail.com> ha scritto:
>> Excellent!
>> Can you please submit it Alessio as the PSC chair?
>> Thanks!
>> Angelos
>> On 4/15/19 3:34 PM, Francesco Bartoli wrote:
>> > Hi Alessio,
>> > The presentation from Paolo is great but I would suggest to use the
>> abstract below from the article written at the beginning of this year.
>> > GeoNode is an open source framework designed to build geospatial
>> content management systems (GeoCMS) and spatial data infrastructure (SDI)
>> nodes. Its development was initiated by the Global Facility for Disaster
>> Reduction and Recovery (GFDRR) in 2009 and adopted by a large number of
>> organizations in the following years. Using an open source stack based on
>> mature and robust frameworks and software like Django, OpenLayers, PostGIS,
>> GeoServer and pycsw, an organization can build on top of GeoNode its SDI or
>> geospatial open data portal. GeoNode provides a large number of user
>> friendly capabilities, broad interoperability using Open Geospatial
>> Consortium (OGC) standards, and a powerful authentication/authorization
>> mechanism. Supported by a vast, diverse and global open source community,
>> GeoNode is an official project of the Open Source Geospatial Foundation
>> (OSGeo).
>> > Francesco
>> > Il 15 apr 2019, 14:31 +0200, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it>, ha scritto:
>> >> Hi Angelos,
>> >> right, thanks for highlighting this. you are right.
>> >> If no other options/volunteers, I can submit it. The most updated one
>> currently is the one submitted by @capooti (Paolo Corti) @ FOSS4G-NA.
>> >> Let me check if I can retrieve it somewhere or if Paolo can send it to
>> us.
>> >>> Il giorno lun 15 apr 2019 alle ore 13:46 Angelos Tzotsos <
>> >>>> Hi all,
>> >>>> We are only 12h from deadline to submit a GeoNode status talk to
>> FOSS4G.
>> >>>> Has anyone submitted this talk?
>> >>>> If not, does anyone have the abstract from last year in order to
>> adapt
>> >>>> and submit?
>> >>>> Best,
>> >>>> Angelos
>> >>>> Angelos Tzotsos, PhD
>> >>>> Charter Member
>> >>>> http://users.ntua.gr/tzotsos
>> >>>> _______________________________________________
>> >>>> geonode-devel mailing list
>> >>>> geonode-devel at lists.osgeo.org
>> >>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> >> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> >> Ing. Alessio Fabiani
>> >> @alfa7691
>> >> Founder/Technical Lead
>> >> GeoSolutions S.A.S.
>> >> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> >> phone: +39 0584 962313
>> >> fax:     +39 0584 1660272
>> >> mob:   +39 331 6233686
>> >> http://www.geo-solutions.it
>> >> http://twitter.com/geosolutions_it
>> >> Con riferimento alla normativa sul trattamento dei dati personali
>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>> si precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> >> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> Charter Member
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190415/6ef7a2f0/attachment-0001.html>
More information about the geonode-devel mailing list
